TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp
HelpingTRresto
resto project for friend. pro mechanic and myself working on. replaced points, condenser, coil, plugs, wires to plugs, rebuilt carbs. do not know what prev owner did. did find a wiring error to ign switch that did not send volts to coil when starter engaged, fixed that. volts jumps from to 0 - 20 and back. thank you all for help! oh by the way starts fine and idles well for a while. fuel pump and lines bypassed with elecric pump. did find that vacuum guage attached to intake manifold at egr port with adapter read only 5 in vac. should we read at ign vac adv port on carb?
NutmegCT
Welcome to BCF.
I'm thinking fuel starvation, likely due to vapor lock. Not enough to kill the engine, but vapor lock would result in insufficient fuel flow.
Just my two cents.
Tom M.
poolboy
Welcome to BCF.
Just my two cents.
Tom M.
resto project for friend. pro mechanic and myself working on. replaced points, condenser, coil, plugs, wires to plugs, rebuilt carbs. do not know what prev owner did. did find a wiring error toWhen i switch that did not send volts to coil when starter engaged, fixed that. volts jumps from to 0 - 20 and back. thank you all for help! oh by the way starts fine and idles well for a while. fuel pump and lines bypassed with elecric pump. did find that vacuum guage attached to intake manifold at egr port with adapter read only 5 in vac. should we read at ign vac adv port on carb?
When it acts up, kill the engine and pull and examine the spark plugs.
As far as the vacuum gauge, it needs to read manifold vacuum.
You won't find that at a location that supplies vacuum to a vacuum ADVANCE module .
If there is a fitting directly on the intake manifold or one for a vacuum RETARD that's the one .
Hamish Racing
Just check the flex hoses in the fuel line toward the rear.
part 85 or 100
They can swell and reduce flow esp if bio fuel is high content.
I had thus on my 3a would be ok at idle revving but would die on a run.
it’s a dollar fix even if it’s something else.
Madflyer
Not only can they swell but leak if you have the fabric cover old lines. the fuel pump can suck air into fuel line that can starve fuel. Two Vacuum is the same as hydraulic any place should get the same reading. At sea level Vacuum could get up to 20 # Look for Vacuum leak at block. What does the RPM due with oil filler cap off
poolboy
When the engine is idling the vacuum will be different at a manifold source than it is at a ported vacuum source.
It's important to know the difference when connecting a vacuum gauge
H
HelpingTRresto
Thank you for the info. 1 less thing to do. Buy the way, progress update. We have gone through the carbs again. Went well. fuel lines done. Ordered new choke cable, it was sticking. All ignition system done. The main issue seems to be distributor not advancing at all. Ordered a new electronic distributor from watford-classics in UK. Thanks to all for your help.
Geo Hahn
...The main issue seems to be distributor not advancing at all...
If all the innards are present and unbroken then that usually means it just needs disassembly and a good cleaning.
Probably something you will want to do if only to have a spare distributor when the electronic one fails.
The stock ignition system is so basic you can hold it all in one hand - takes so little space I always carry a spare of everything and sort out any problem when I get home:
sid m
RJS
Mine did similar. Check low tension lead to coil. Over time vibration caused the wire to fail at the spade connector. Only acted up when motor at full operating temp. Stripped wire and reconnected spade. All good
H
HelpingTRresto
I really appreciate everyones input. got accuspark electronic distributor from watford-classics. probably could repair old one, however owner wanted to go electronic to omit points. new one cost about what we might spend working on old one. found the new one on ebay. It works great. problem solved. the major running issue was no timing advance in old dist. car runs and drives as good as new. owner thrilled. best regards to all.
KVH General Tech TR4A Runs Terrific Triumph 2
Paulus TR4/4A TR4A Engine runs on Triumph 11
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
