TR4/4A 67 IRS Damper arm/link removal help
JDstr4a
Finally back at it, and need some help with removing the lever and damper arm connection. Do I need to remove the whole damper and have the link pressed out? Seems to be solidly in there and the new ones seem to have a taper. Maybe I'm just short of patience.
Thanks.
JD
TR3driver
Great Pumpkin - R.I.P
On my (solid axle) TR3, I use one of these
https://www.amazon.com/Tool-Aid-619...1435357305&sr=1-41&keywords=tie+rod+separator
J
JDstr4a
Thanks Randall. Is there clearance to do it on the car, or would you recommend taking the whole assembly off and doing it on the bench? Do I need another tool to put the new one in?
TR3driver
Sorry, I don't know about doing it on the car on a 4A. It can be done on a TR3, though.
Easy way to install a new one is to use a plain nut the first time, to pull the taper until it locks. Then you can remove the plain nut and install a new Nyloc. (Nylocs shouldn't be reused.) Or another route is to just use a big pair of pliers to hold the joint together while you tighten the nut.
KVH
It can definitely be done on the car. The tool I have is like Randall's (now available from Moss), and though a tight fit, it does fit. Having said that, I'm unsure of your question. You don't mention the ball joint or tie rods, and at first I thought you meant the rear shock arms of 4A. You are talking about the ball joint between the upper control arms, right? Note that Moss (and your local parts dealer) also sells a small separator used more for tie rods, and if you're talking about the rear lever shocks it's best suited to that as well in my opinion. You'll know it when you see it online, or Randall or I can shoot a picture of that too. Or maybe this one is clear enough:
attachment.php
TR3driver
Perhaps I'm confused, but I thought we were talking about this joint at the rear
untitled_1.jpg~original
J
JDstr4a
Randall is correct, I'm trying to remove #20 from #17. The ds damper link is shot though the dampers seem fine and are not leaking. I've replaced the springs and thought I should replace both damper links while she was up on stands.
J
JDstr4a
Picked up a separator locally and have one replaced. Can't seem to find a torque spec for the damper arm to link nut. Any suggestions?
Thanks
JD
J
JDstr4a
Done, clunking stopped, thanks for all your support. Front wheel bearings next, but too nice out to start today!
TR3driver
Oops, sorry I'm late. But I think this is the torque spec for that nut.
untitled_4.jpg~original
J
JDstr4a
I saw that, but the suspension arm side of the link is 9/16 and the damper side is 11/16, so I just "tightened" them and I'll keep an eye on them. What a difference replacing these made. Thanks again for your help.
B TR4/4A Measurement of "IRS" badge Holes Triumph 1
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
J Wanted Tr4a irs frame Triumph Classifieds 1
L For Sale late tr4a IRS project Triumph Classifieds 0
Scotsman TR4/4A TR4a Live axle vs IRS Triumph 13
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
J TR4/4A TR4A IRS Grille Question Triumph 4
S TR6 Would a IRS TR-4A body bolt on to a TR-6 frame??? Triumph 4
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
KVH TR4/4A Noise from the Rear--IRS Triumph 4
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
G TR4/4A irs differential Triumph 7
G TR4/4A tr4a irs left rear wheel Triumph 14
H TR4/4A Trailing Arm IRS Triumph 6
alanjohnturner TR6 Trailing arm brackets - any IRS car Triumph 2
6TTR3A TR6 Replacing the IRS u-joints on a TR6 Triumph 15
glemon Cheap Insurance [Triumph TR IRS Reinforcement] Triumph 2
C TR4/4A TRIUMPH TR4A iRS For Sale - NUT & BOLT RESTORATION--[CONCOURS CONDITION] Triumph 2
C TR4/4A 1967 TR4A IRS motor mounts Triumph 7
T TR4/4A TR4 IRS boot instalation Triumph 15
Zimmycobra TR4/4A TR4A IRS Differential Mounts Triumph 8
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
J 67 IRS Exhaust Tips Triumph 2
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
T TR4/4A 65 triumph tr4a-irs tires Triumph 7
J TR4/4A TR4A IRS Trunk Triumph 3
J TR4/4A TR4A IRS Exhaust Triumph 5
T TR6 TR4a IRS vs TR6 handling Triumph 20
P IRS swingarm alignment shims Triumph 2
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J TR4/4A TR4A IRS Clamps, Belt and Suspenders? Triumph 4
R IRS Rear Axles Triumph 16
J TR4/4A TR4A IRS Exhaust Triumph 11
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
J TR4/4A TR4A IRS Jack Stands Triumph 6
J Putting the IRS on stands ??? Triumph 5
J TR4/4A Shock Absorbers TR4A IRS Triumph 3
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
R TR4/4A Tr4a irs, name plate question Triumph 13
J TR4/4A 67 TR4A IRS Hood Bumpers-Cones or Flat? Triumph 8
