Have a 67 BJ8 3000 MkIII. New wireing harness was put in but tach does not work & does not look to be wired properly.
At the back are the 2 male spade posts for the white wires. Should the tach be wired with the from the white coil wire to the tach & then out of the tach through the ignition switch? or ?????????
Any insite would be appreciated.
Thanks,
R&M /ubbthreads/images/graemlins/confused.gif
Thanks,
Hi Guest!
