Jim_Gruber
One other thought. I spent an entire afternoon trying to extract a set of wishbones from a Spridget about to be scrapped out. After I got the wishbones home and started cleaning them up I discovered both wishbones were cracked and were unusable. Wishbones on RB Spridgets are much heavier duty than on early Spridgets. If you look for a used replacement wishbone go for one out of a later RB Spridget. MOSS/VB sells two versions of Wishbones. The more expensive ones are similiar to the RB OEM Equipment. After seeing how problematic the early ones are, especially those not getting regular lubrication, I'd go for the later type wishbones.
Even if you opt to go for new Wishbones, your kingpins will need to be reamed to fit. Tool is $250 from MOSS, this is one easily outsourced to Peter C.'s crew.
I've done this twice in the past 10 years. First time I simply replaced really worn out parts with a bolt on complete suspension assembly from a later Spridget and just replaced rubber bushings. My rebuild last year covered everything from soup to nuts. It's not all that hard to do but is time consuming and you'll need assistance from other vendors generally to do it right. Happy to take any questions on what I did to get Bugsy handling like a go cart once again.
