AUSMHLY
64 BJ8. There are two chrome pieces that get fitted to the hood air intake area. The Surround Assembly and the grill air intake.
Question is, does the top of the small grill air intake fit inside the hood air intake slot and the Surround Assembly on top of the hood. Thereby having the sheet metal of the hood between the two pieces?
Or does the Surround Assembley air intake lay right on top of the Grill air intake. Then both pieces together go on top of the hood and get bolted through the three holes?
Fresh paint job and don't want to scratch it, trying to figure how assembly goes.
I plan on using 3 nylon lock nuts to tork it down. Any suggestions as to how to do this, so as not to put dimples in the Surround Assembly air intake when tightening it down?
Thank you, Roger
Thank you, Roger
Hi Guest!
