Martin Mieger
Hello All: I am having a problem with my trans.The clutch is good from the"start in gear" test,but will not go in to gear when running.The real poser is that all works great when I jack the rear wheels off the ground.The car has had the later all syncro trans installed by the prior owner.All worked well for a while then this just showed up one day.Leave it to Murphy.Thank for any help Martin
