64 front end too high
AUSMHLY
Barrett-Jackson is this week. I noticed this 64 Healey. Curious....What would cause the front end to be so high?
https://barrett-jackson.com/Events/Event/Details/1964-AUSTIN-HEALEY-3000-BJ8-ROADSTER-237079
Keoke
I think the car is leaning to the right ??
red57
Both ends are too high IMO. Possibly no engine or tranny?
Between the stance and the rear view mirrors on the wrong sides, I'd be wondering what else was done wrong.....
RAC68
Hi All,
Bob, what looks odd about the thermostat housing?
It is a Phase 1 BJ8 and should be even lower them a comparable Phase 2. I'd bet they installed new or re-arched springs at both ends very recently and they haven't begun to settle yet.
Ray(64BJ8P1)
red57
When I saw this last night I didn't see the link to the auction site. After looking at the pictures in the link, I think I'm right about no engine/tranny explaining the stance. If you look closely at the last picture (straight on from the front) you can see the front cross member thru the grill slats - that crossmember is behind the radiator when it's installed so I think the pictures were taken before the motor was installed (at the very least before the radiator went in). So, probably looks better now that it has some weight in it.
John Turney
Yes, that proves the engine was clearly out. The engine photo shows the engine in the car. Wonder why they didn't take photos of the outside with the engine in?
Actually, I like this one better https://barrett-jackson.com/Events/...N-HEALEY-3000-MARK-III-BJ8-CONVERTIBLE-236964, but then I know the owner and car.
Editor_Reid
Platinum
Wow....! I haven't seen that one before.
Yeah, and just think, "Steves Auto Parts" put their name on that thing as they must have calculated that it would be good for business. If I owned a Healey back then it would have made me run the other way!
And they used to say that it was those crazy Californians who were butchering Healeys with all kinds of crazy mods.
Jack T
The cross brace is visible through the grille with the rad in place. That's why the factory painted them flat black.
red57
Yes, you can see the angle iron cross brace is black and is in front of the where the radiator sits. But, in the picture, you can also see the crossmember that dips down in the middle to clear the crank nut and it sits behind the rad & is not visible when the rad is in place.
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
B TR2/3/3A Front end alignment Triumph 23
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
S TR2/3/3A Front end alignment and tire wear Triumph 9
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
S Finally got my front end back together Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
K TR6 TR6 front end Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
B Bugeye front end Spridgets 0
H Should I drop the front end down a little? Austin Healey 25
M Advice on doing a front end rebuild via kit? Spridgets 4
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
MY66AH Front end question Spridgets 9
regularman Has anyone here put a bugeye front end on a square Spridgets 2
bugedd Lowering front end Spridgets 8
