tony barnhill
Great Pumpkin - R.I.P
Re: All Her Hidden Secrets Revealed...
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Guess you got the heat pump working.[/QUOTE]
No, repair guy is here now...its calling for heat but the compressor's not coming on.....&, if the compressor is bad, the entire unit, under house & outside, has to be changed because the gov't apparently has changed specifications & older units can't be matched anymore! & we replaced the air handler under the house 2 or 3 years ago!
