'63 Midget Rear End
tony barnhill
Great Pumpkin - R.I.P
This is now under my little car...what a bitch; not hooking everything up, just getting it up under there by myself...unlike an MGB rear end, this little sucker is too small & not center balanced enough to just sit on a floor jack!
Everything is finger tight right now....I'm cleaning up the park brake assembly & after its installed, I'll tighten things up a bit & set her on her wheels.
Another major milestone!
(Oh, if you look at the driver side of the differential case, you'll see a little silver band going around it - out near the elliptic spring tower...it holds the brake line to the case...I lost one of mine...anybody got an extra?)
uh oh! That was supposed to be painted. :smile:
tony barnhill
tony barnhill
tosoutherncars said:
Minus four points for originality... tsk tsk.
& where would that be? :lol: the missing clamp?
jlaird
Alum on rear case and tranny are supose to be painted, rear end black and tranny engine color.
bugimike
:iagree: Not original, but clean, bare aluminum looks MUCH nicer IMHO!! :wink:
tony barnhill
tony barnhill
Not on a Midget, Jack.....on an early Midget the differential itself (aluminum 3rd member) is natural, the differential case is black....the transmission is natural.
There ARE some differences between the Bugeye & the Midget!
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Not original, but clean, bare aluminum looks MUCH nicer IMHO!! [/QUOTE]
On an early Midget, this <span style="font-weight: bold">IS</span> original! Remember, I took the car apart & found no sign of paint on the 3rd member or transmission (& on MGB's they are also both natural)...& some old factory/advertising photos I've got show them unpainted..remember, MG was always looking at ways to cut costs & they assembled lots of things just as the arrived at Abingdon.
jlaird
Intresting to say the least.
Somewhere we got to get a concourse guide.
jlaird
I do however think the bare alum. looks better than the painted.
tony barnhill
tony barnhill
Hey, Kim - is yours bright red?
tony barnhill
tony barnhill
Concourse guide for Bugeye or Srite wouldn't mean anything to the restoration/judging of a Midget....that's one of the things I've got against "The Original Sprite & Midget" - its too broad to be worth much.
Oh, I just slid up under my '74 RWA with a flashlight...I'm the 2nd owner & the female original owner from whom we got it never did anything to it except repairs.....3rd member is dirty but unpainted as is the transmission.
jlaird
We need all the Spridget concourse guides.
tony barnhill
tony barnhill
One of the things I've never liked about the term "Spridget" is that it tries to homolgate the Sprite & the Midget into the same car - they're not!
JPSmit
Not entirely sure I agree - we might actually get serious around here. :banana:
FWIW prior to my dismantling, everything was a lovely shade of oil - and it seemed to have come that way from the factory :laugh:
blkcorvair
I must agree Tony I have several Diffs at Home. Two From Midgets (Both Natural in Color) and two From Sprites (Both have black Paint on em.)
RickB
Hi Scott, how's everything going?
So when you say "natural color" do you mean rust brown?
That's the color of mine, and I'd consider that to be "natural".
:wink:
I do not know about the color of diffs. Honestly, I do not care, but I could see where there should be two separate concours guides (I thought there was). However, to say that they are "two different cars" may be a bit much. The differences in any given model year are superficial at best.
M Sprite/ Midget rear end Spridgets 9
C Need info on gearbox and rear end oil for midget Spridgets 5
B RX7 Rear End in a Midget Racing 3
G 1967 Midget rear end leaks oil Spridgets 12
R 79 MG Midget rear end tragedy MG 10
D MG Midget 1275 rear oil seal. Spridgets 0
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
AngliaGT Midget Rear View Mirror - What Will Work? Spridgets 1
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K MG Midget rear drivers side spring sag? Spridgets 7
K General Tech MG Midget rear spring sag? MG 2
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
HealeyRick Safely Alert - Midget/Spridget Rear Brakes Spridgets 2
B Looking for rear marker light for 73 midget...just need the socket part or whole,also Spridgets 0
T 76 midget rear wheel cylinder Spridgets 5
T 76 midget rear brake lock up Spridgets 3
RickB SWA formerly RB Midget needs rear fender flaring Spridgets 60
J Rear Springs Midget Spridgets 10
R Midget chrome bumper conversion rear corner caps? MG 1
P how to replace rear main seal in 1500 midget Spridgets 2
bcbug 76 midget rear brake assemble question Spridgets 2
bcbug midget rear brake shoes adjusters Spridgets 4
M Midget Top - Rear Window needs help Spridgets 2
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
J Rear side marker lamps-79 midget Spridgets 9
tony barnhill Midget MkI Rear Wire Wheel Hub Spridgets 4
drooartz Wheels w/o rear axles, or a Midget dolly Spridgets 1
M rear mont holes on a 76 midget Spridgets 25
Gearhead Rear disc brakes on a Midget Spridgets 2
A Need Rear Bumper for 76 Midget Spridgets 4
77_MG_Midget 77 midget rear shock conversion Spridgets 2
R rear axle search for 79 Midget Spridgets 7
B Midget rear lowering springs Austin Healey 0
B Midget rear lowering springs MG 2
nathandarby67 Swapping rear hub on a Midget MG 7
S 79 Midget with rear wheel noise MG 3
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
