TR4/4A '62 TR4 rear end clunk
TR4CB
When i go over a bump i notice a hollow clunk noise from behind my drivers seat. It sounds as if the body area to the left and center of the trunk is hitting the frame or as if the spare tire is slamming down but the boot is empty. Nothing looks out of place underneath and I cant replecate the sound by leaning on the rear quarter. Can you guys tell me where to start looking. Thanks so much.
LarryK
How old are the shocks? Bushings on shocks? Do your bumpstops still exist?
TR4nut
I think on your TR4, there are no bump stops other than the rubber buffers mounted on the differential itself. I'd go with any of the other opinions on those banging noises - but you may need to get under the car to see if you spot any potential noise sources.
Randy
KVH
I agree with the Mace man. Very likely just loose bolts on the shock. Happens all the time.
Check it out--don't over-tighten. Interestingly, my manual does not call for lock washers. Does yours?
TRMark
Bronze
I think you and Andy called it. Regular maintenance on a TR4. I just repaired my 63 last night. The manual calls for a bolt with a plain washer and a nyloc nut. The problem is that there is not enough clearance between the shock body and bolt head to get a socket wrench on it; you end up wedging a screw driver to hold the bolt in place while tightening the nut. I replaced the bolts with a socket head bolts (fine thread) socket heads use an allen wrench. Because of the small head size of the socket head I trimmed down a flat washer to just fit the area of the shock body. On the back side I used a flat washer and a steel lock nut. Use the thickest washer you can find. We'll see how this works.
The other thing is the holes in the shock bracket oval out. Some years I clamped a piece of copper plate on the back side of the bracket and mig welded the hole a bit smaller. I then redrilled it and filed and ground things flat. The copper keeps the weld material from the back side.
YankeeTR
Did you check to see if maybe Jimmy Hoffa's body might be in your trunk...you never know!
kodanja
Isn't that the sound their supposed to make?
Got_All_4 TR4/4A TR4 Detroit Locker Positraction Rear End Triumph 6
G TR4/4A tr4 rear end in a tr3a Triumph 10
KVH TR4/4A TR4 Rear End Again Triumph 4
KVH TR4/4A TR4 Rear End Again Triumph 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
S TR4/4A TR4 front and rear suspension Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
M TR4/4A tr4 zip out rear window Triumph 6
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
F TR4/4A TR4 rear trim Triumph 2
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
TR4v8 TR4/4A tr4 rear axle width Triumph 0
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
M TR4/4A TR4 rear sway bar installation Triumph 15
CinneaghTR TR5/TR250 TR4/RA/250 Rear Bumper Installation Triumph 3
R TR4/4A TR4-A rear fender Triumph 12
D TR4/4A TR4 - Rear wheel slot key removal Triumph 8
J TR4/4A TR4 rear suspension Triumph 8
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
KVH TR4/4A TR4 Rear Wheel Studs Triumph 6
T TR4/4A Early TR4 Rear Suspension Triumph 22
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
Tabcon TR4/4A TR4 Rear Brake Parts? Triumph 25
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
SCguy TR4/4A TR4 rear axle piece fell of into my hand? Triumph 21
PeterK TR4/4A TR4 Rear track bar pictures and info needed Triumph 6
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
D TR4/4A TR4 rear diff pinion seal Triumph 4
KVH TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4 Triumph 6
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T tr4-rear tube shocks Racing 2
P TR4/4A tr4 rear hub problem Triumph 16
