62 / BT7 windshield
  • Thread starter Deleted member 21878
  • Start date
my windshield has a number of wiper scratches in it and after trying to polish them out for a day, i gave up. they don't seem that deep but i guess i do not have the equipment to get the job done. So i took my glass over to the local auto glass shop and asked the guy if he could get me the glass. it needs new seals and all so i just wanted to get the glass. his book listed glass for a 63-67 Mark II but nothing for a 62.
my question is: is that the same glass. my VIN number is 16183 so is it possible it uses the same glass as the 63? which i believe would be a BJ7 model. as you can see in the pic attached it is not flat glass. IMG_0255.jpg
Thanks
Jerry
I think it is the same glass, someone smarter will confirm. I tried polishing scratches out also, a waste of time.
Jack T
Glass for a 63-67 Healey will definitely not fit a BT7. As for polishing, it will work but takes a long time with the right equipment. I used an Eastwood kit and was happy with the result. The wiper tracks that were noticeable are now very faint. Having the windshield out of the car so you can work on a horizontal surface helps. It does make a mess, as you use plenty of water.
thanks. i knew Moss had them. but since i was not going Tri-plex, figured i would look local. freight has to be high on these things. but guess i will need to get one shipped from somewhere.
HealeyRick
Again, if you are going to have it shipped, give these folks a call. Their prices were much better than the usual suspects: https://www.prosourceglassintl.com/index.html
C Removing windshield from Austin Healey 3000 BT7 Austin Healey 2
F BT7 Windshield Washer Pump Austin Healey 1
B Windshield installation BN6 +7 , BT7 Austin Healey 12
bighealeysource Rubber seal on windshield frame of BT7 Austin Healey 0
P Windshield Posts on a BT7 Austin Healey 1
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
