'61 Morris Minor Disc Brake Conversion
bcliff
My '61 Traveller has the original 7" drum brakes. Since it is my daily driver, I'd really like to convert it to disc front brakes. I would be using an MG midget as a donor for parts. Exactly which parts are used from the midget? I have looked at several cars that have had this done, but none of the owners actually did the work themselves. Some tell me it is a strictly bolt-on procedure, others tell me there is some fabrication involved. I need an exact list of which parts I will be using (Spindles, wheel bearings, etc) and if there is any machining to be done.
Thanks,
Bruce /ubbthreads/images/graemlins/driving.gif
piman
Hello Bruce,
I used Midget brakes on the front of our Traveller. I used the Midget front hubs, discs and calipers. All I had to do was fabricate a mounting plate to attach the calipers to the upright. There is a small seal at the front of the master cylinder internal assembly, this seal should be removed or the pads will bind.
Alec
john_j
Sorry this answer is so late, might not help the OP, but someone may find it useful. You can use the front uprights and discs from a Morris Marina (may have been called Austin in the US), as they used practically the same suspension as a minor.
piman
Hello John,
ah, but if you do you also need to fit Marina wheels as the stud pitch is different.
Alec
P Morris Minor disc brakes Other British Cars 8
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 7
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
NutmegCT Rear dampers, 1957 Morris Minor Other British Cars 4
NutmegCT Morris Minor brakes! Other British Cars 9
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Morris Minor horn mystery British Motor Corp 12
NutmegCT 1957 Morris Minor Traveller Other British Cars 20
Bob Claffie Morris Minor Other British Cars 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
Bayless Need soft top for Morris Minor Other British Cars 5
D Morris Minor in NSB Florida Spotted 8
AngliaGT Morris Minor Spotted 1
Griz Wanted Morris Minor Other British Classifieds 3
Sarastro Morris Minor in Long Beach, CA Spotted 1
Gerard ... for the Morris Minor enthusiasts here... Spridgets 18
M Rubber for Morris Minor Spring Clips Other British Cars 1
M Morris Minor Spring Clip Rubber Other British Cars 0
4tecdog Fleet of new Morris Minor Vans 1964 Other British Cars 4
drooartz Up-date on the 4-door Spridget [Morris Minor] Spridgets 12
catfood Timewarp Morris Minor Other British Cars 0
D Morris Minor motor mount? Other British Cars 3
S Morris Minor resources? Other British Cars 6
Gliderman8 '59 Morris Minor in Taupo, NZ Spotted 0
NutmegCT Morris Minor for sale Other British Cars 1
TulsaFred Morris Minor? Spridgets 7
dougie Morris Minor Panel Van Other British Cars 4
AngliaGT Morris Minor Convertible Other British Cars 0
K Reasonable price for a Morris Minor project car? Other British Cars 4
O Morris Minor Questions? Other British Cars 3
O Morris Minor on the horizon? Other British Cars 4
M Proper Brake Fluid For 1960 Morris Minor Pick Up Spridgets 8
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
B Datsun engine & trans in a Morris Minor? Other British Cars 0
5 wheezy Morris Minor 1000 Other British Cars 2
AngliaGT Morris Minor on Front Page Other British Cars 3
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
jackq Morris Minor woody wagon. Other British Cars 7
AngliaGT Morris Minor Convertible - $1424 Other British Cars 7
G Morris Minor under body resto Restoration & Tools 2
C Morris Minor & Mini's Auction Other British Cars 0
G Morris Minor Help Other British Cars 10
T Morris Minor Traveller For Sale? Other British Cars 1
YankeeTR $1900.00 Morris Minor? MG 15
S 1960 Morris Mini Minor British Motor Corp 2
bcliff Anyone want a '61 Morris Minor Traveller? Other British Cars 0
jackq 52 Morris Minor Other British Cars 3
jackq Morris Minor Other British Cars 0
Schroeders Any Fellow Morris Minor Pickup Heads Around? Other British Cars 7
