Nothing to do with cars, but I thought I'd post it here to tap into your minds for a possible solution to a problem I've had/have with this little engine.
I have a 6hp Tecumseh vertical shaft on a Sears mower. It started blowing oil out the crankcase vent, which is the later style with the vent on the top and rear of the case and vents into the carburetor. Since I thought it was because of piston blow by over pressurizing the case, I rebuilt the engine, new rings etc. The cylinder was in perfect condition. I also replaced the vent valve assembly in the block. Started it up and it is still blowing oil out the vent tube. Anyone have a cure for this? Don't say get a new engine, that's out of the question, I'll buy a new mower first! There is a reason for this and I would like to know what it is. I bought this mower new and it's only ever been used for trimming, so it's never been worked hard. Any help would be appreciated. Oh yeah, I didn't cross hatch the cylinder before installing the piston, which might have been a mistake making seating the new rings take much longer. PJ
