Well fellow MGA'ers.....Help... I am into replacing my rear wheel cylinders ...fronts went great ...Here is my dilemma...Since this is has been a 12 year project (getting close)...somewhere along the way I ended up with two new rear wheel cylinders..one BMC part number KWI 10, 17H7512, and a Lockheed part number 88692. Parts are identical. Both of these vintage boxes had a cross ref # of GWC1108 penned on them. I know the correct part is GWC 1111. The cylinders fit in their respective slots just fine ..but ..instead of the lever side having those two slightly raised tabs for the adjuster....they just have a slot for the brake shoe ends.....which means no adjuster.....UNLESS...by adjusting the Emergency Brake cable...from the pivot ... the adjustment would be taking place... ?? Has anyone run into these puppies before...? Am I correct on my thinking (feeble though it be)..? Or should I go online and search for a reasonable set (seems such a waste to not use these).... IDEAS and suggestions are more than welcome...thanks Porkchop ...
