PatGalvin
Sorting through the brake hydraulics. My 5-way valve is fitted with the restrictor including the spring loaded piston (presumably to prevent fluid from flowing back towards the MC. Can I remove the piston and spring or is it essential to keep this feature? If essential to keep the guts of this restrictor, can someone show a photo or sketch of how to reassemble this restrictor valve? I must have reassembled it incorrectly, as no fluid would flow through the valve. I removed it and cleaned it out (for a second time). Ready to reassemble.
Thanks much
Pat
Thanks much
Pat
