Steve_S
Bob, perhaps you didn't read my post in its entirety? I have them sitting in my garage. As I said, the first cost me $250 plus an $850 rebuild. The other two cost me $200 each plus shipping and they too will need to be rebuilt (obviously). If an overdrive box is completely trashed then you can expect to pay a bit more for a rebuild, probably more like $1100-1200. If you had acted a couple years ago, you could have bought a truckload of them from Moss, fully rebuilt with warranty for $1400 each.bob67bgt said:If you can come up with rebuilt 3 syncro overdrives at $1100 that would be amazing
I must respectfully, yet completely disagree that a T9 box feels the same as a Mowog box. Even the 3-sync versus 4-sync Mowog boxes feel completely different from one another - different enough that many owners of Mark I MGBs won't install 4-sync models in their cars. The T9 box is a wonderful piece of kit, but it does not feel or sound the same.
I suspect your views on cost may be due to limiting yourself to the usual suppliers within the continental US. Shopping in the states, the overdrive module and related components are the most expensive parts, while the rest of the gearbox can be found easily for free, assuming you bought an overdrive kit without a gearbox attached. So your quote of $875 plus a free gearbox, and then paying someone to build it up should bring your total to around $1500. Not too shabby for a brand new OD transmission!
As an example... how about a working, tested overdrive 4-sync gearbox delivered to your door for $890? Click here. You can buy them all day at that price.
As for durability, 3-sync gearboxes are certainly less robust in certain areas than 4-sync LH units, mainly layshaft bearings. I did pretty well on a non-OD 3-sync box by getting 250,000 miles out of it before a rebuild was necessary but that's unusual. They usually don't last more than two engine rebuilds in my experience. Later models usually outlast the early ones by quite a bit because of the larger layshaft and bearings. When I finally had my 3-sync rebuilt, I had the larger shaft and double bearings installed, so theoretically it should be as strong as a later one which is good since it will be going into a car with 150+ HP. An LH OD module would have been a better idea for this car but the OD will be mainly for highway use so it should be fine, and I really do prefer the feel of the early box over the later one. Just personal preference, really.
If you don't like comparing ideas then you're in the wrong place! :wink:bob67bgt said:Now you see why i do not normally post on this kind of thread...Bob
A fourth time now I will try to help and will go as far as to search the web for you, but I'm not calling England on my dime! :wink:
