64rocksprite
OK, so if you haven't seen it:
check e-bay item # 110252409704
After reading the description, it seemed a hybrid Rivergate/Morrisservice kit. Here is the answer I got to "how did this kit come together?"
"Hi, I put the kit together myself buying from several sources. The adapter IS from Pack racing in AZ but is not listed on their website. I bought it here on e-bay. The flywheel can easily be used with an MG cover if you wish, just buy Rivercate's clutch disc. It is already drilled and tapped for the Datsun cover, including pin holes, just shifted over 1/3 of the flywheel distance so as to have a fresh area to drill on. All I have is all that is listed. Like the Rivergate kit you have to buy the speed-o set-up seperately. Fastener's are readily available from any good hardware store. This is the only kit I have and I do NOT plan on making any more for sale or personal use so this is it. Thank you for the inquiry and good luck bidding. Regards, Bret"
So - what do you guys think? temptation of course is to assume it all works and if it can be had for $4-500, its a good deal. The other half of me says: Look dummy, buy the complete kit from either Rivergate or MorrisService (I'm leaning toward Paul A's kit) so you have support..probably worth the extra $400 for someone doing their first 5spd conversion.
Has anyone heard of Pack racing making this adapter? Perhaps there is a reason they no longer make it(?)
Thanks all..
Thanks all..
