Stewart
Had a nice perfect drive in the country and got all the way back to my apt. and made the mistake of checking the mail. Get back out to the car turn the key and nothing. Everything is dead. Push the car around the building back to my garage and find the nut that holds the battery lead to the starter had come off. Then to top it off I find coolant leaking out of the stud on the pass side above #3 cyl. #1 on the torque sequence.
So does anyone off hand know what the nut size is for the starter? Also since the head is coming off are the studs from advance performance worth the dollars? I'm not very happy with the current moss ones.
Car was running so nice too. Solid 75psi oil presure after 30 minutes on the highway temp was right at N and she really moved when the skinny pedal was pushed.
Hi Guest!
