NardisCNC
The other day I had my mechanic change a couple tires on my 66 midget because that's one of those jobs I'd rather leave to somebody else. Being the nice mechanic he is, mine was one of the 2 cars he backed in his 2 car garage to keep it out of the rain. When he went to pull it out the next day, it only wanted to go in one direction REVERSE!!
So here are the details: In the neutral position you can wiggle the shifter left to right, that is, the left and right positions, as they relate to gears 1/2 & 3/4 and the car goes in reverse when the clutch is let out. You cannot put it in the far right position OR reverse (the gear it's stuck in). The shifter WILL go into the 3/4 gear positions, but when you let out the clutch the car goes nowhere as if the tranny is locked up and you can hear the engine straining. (I gently did this to avoid damaging anything further).
Based on this info, does anyone know of a common problem that might cause this? I'm assuming I'll have to pull the engine and trans to fix this? Or could it MAYBE be fixed without pulling?? It's a ribcase gearbox if that makes any difference.
I was REALLY hoping to have this fixed by the weekend so I could drive it to the British Bash in Louisville. Not that it's a show car, it's just the thing to do. Any words of wisdom are greatly appreciated!!
Hi Guest!
