That number appears to be obsolete, not listed on the Hopkins web site. But the 48845 appears to be similar. Website says the 2.1 amps limit is per stop outlet, which makes a little more sense.The Hoppy converter is available on the internet or at your FLAPS. Part number is 38845
It is recommended that you convert your rear turn signal lights to LEDs.
The HOPPY converter cannot handle much more than
2.1 amps total.
The one that RG linked to above can be wired either way. https://www.etrailer.com/static/images/pics/s/t/stl79rb_10_250.jpg Just ground the red wire (black too if you want) and link the white wire to your brake light switch.Any thoughts for a positive ground CHMSL? I do run positive ground LED brake lights...
Would love Don's solution if positive ground.
