365-7 Gearbox part needed
Dug
Hello,
I’m hoping one of you might be able to help or point me in a direction of 365-7 gearbox parts. I’m looking to find (make that hoping) 2nd gear and a 1st-2nd slider assembly.
The gearbox that’s being worked on now has all the gears disassembled off the main shaft and have found second gear very chewed up with the slider side of second looking bad as well.
We have the bulk rings but now need help finding the other bad parts. New or good used would be great, if I may ask where would you send a guy to start looking?
Thank you in advance, I could really use the help.
As long as you don’t hold it against me I stay mostly in the spridget side of the forum.
Thanks
Dug
Europa is the model, 74 is the year if that makes a difference.
Dug
There is a bloke on e'bay that has many bits. Look under the stores area. He is from northern caifornia.
Cheers,
D.
