Bob_Spidell
...The Valvoline vr1 is available here (20W-50) but is available in mineral format and none. Which is right? ...
Not sure I understand the question but, yes, VR1 is a mineral oil (non-synthetic).
Hi Guest!
Hi and thanks for the reply.
Hello James, welcome to the forum. As stated above there is way too much paranoia about oil pressure. Your oil pressure is not bad and if you want to get it a little better put a little bit higher weight multi grade oil in it. Especially a racing oil that can withstand the heat. I'm using 20w-50 Valvoline Racing Oil right now. As long as the engine doesn't have the wrong kind of noises, (rod knock, excessive valve clatter), etc then it'll go for a long time. Enjoy it, Cheers.
Hi James
In the UK the silver is mineral and the black synthetic, there is about £10 sterling difference in price and the synthetic usually sells for around £39 and £29 for mineral.
A useful video
FWIW the geared Healey oil pump is prone to wear whereas the vane version maintains its efficiency for longer and even when it's scored, but there isn't much difference in pressure when both are in good condition.
Wonder why DWR calls their vane pump 'High Capacity?'
In my search however I found Gulf Classic SAE 20-50
https://gasolin.no/index.php?main_page=product_info&cPath=24_75&products_id=12936
Any idea if this is the same, better or worse??
James
