3000 BJ8 Door Seals
Mag9
I installed new door seals on my BJ8 and not sure they are correct. Do they end before the top bend or continue up over the top as in the photos? Concerned they will not stay at the sharp bend. I have 2 small screws to further attach them but not sure where to insert if correct. Seals are MacGregor product. Great product!!!
Thanks for comments
vette
I'm pretty sure that you have it correctly installed. I used MacGregor seals on my BJ7 and I like them although at the time I had the same question as you and I terminated them incorrectly. But I believe you have it right. If I find a picture in one of the restoration guides I will post it.
vette
It's the best pic I could find.
Top Down Resto
There originally was a small pozi drive flat head sheet metal screw that held the furflex fast to the metal vinyl covered panel . Ive seen two screws used on some BJ8s to hold a stubborn section of the furflex seal.
The rubber part of the seal Im afraid does get terminated under the clip as well. It was originally trimmed a bit thinner so it all fit and was hid under the clip.
Top Down Resto
the upper photo is the back side of the seal , you can see the rubber terminating under the clip , this is on my unrestored 65 bj8. An original 67 I had in the shop had the rubber bulb trimmed a little to help fit under the clip, Ive had to do this to get them look nice too .
The second photo shows the pozi drive screw that helped hold the furflex seal to the panel. There should be a hole there if you look , Ive always seen them on the convertible cars.
Hope this clears it up for you.
Carroll
Patrick67BJ8
Carroll
Thanks for sharing the photos! That bend is almost 90 degrees and I thought that maybe cutting a V at that point would relieve the stress making it look better.
Top Down Resto
Hi Patrick, good to hear from you again, I do enjoy the news letters you send me !
Ive had good luck installing the furflex seals , they bunch up a little in the corner, but look at the original it has that too. The modern bulbs are a tad bigger necessitating a little hidden slice cut to make them smaller so the clip fits on nice.
M
Mag9
Thanks to all for the information. I believe I installed them correctly. The addition of the small screw really locked them down. McGregor seals are awesome and he even included the two small screw plus advise.
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
Patrick67BJ8 Early 3000 vs BJ8 vin Austin Healey 3
J 3000 bj8 Oil Pump Austin Healey 38
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
S 1967 3000 MK3 BJ8 Suspension is so stiff - any chance to improve comfort ? Austin Healey 10
G Lens screw for AH 3000 BJ8 Austin Healey 1
G Correct location of front turn signal on bj8 3000 Austin Healey 3
K 3000 BJ8 For sale in LA need PPI Austin Healey 17
memphis Panel Switch Wiring 3000 BJ8 Austin Healey 4
davidb AH 3000 BJ8 tachometer Austin Healey 10
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
H Need help with, 1966 3000 BJ8 WShield Post Install Austin Healey 2
B 3000 [not BJ8] Rear Springs - too stiff - why? Austin Healey 6
MadRiver BJ8 Center Console 3000 Badge Question Austin Healey 13
A Correct Color For BJ8 Radio Cover "3000" Badge ? Austin Healey 18
David_K AH 3000 BJ8 value and restoration? Austin Healey 9
K AH 3000 BJ8 restoration project Austin Healey 2
R 67 BJ8 3000 Tach Wiring Austin Healey 3
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
M Engine Stand for 3000 Motor Austin Healey 7
D Healey 3000 BT7 rear panels Austin Healey 0
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
