Hi Guest!
Contact Nick Freeman of Nical Engineering in the UK. He has the manifolds and can help you with the setup, etc.rjc157 said:thinking of doing a conversion is anyone out there running 3 hd8 carbs and what they used as far a manifolds
HealeyRick said:At the risk of being the skunk at the picnic ... what else are you planning on doing to your car? To take advantage of that extra fuel, you are probably going to want a hotter cam, improved head, exhaust and ignition. My BJ7 had a BJ8 cam and 3 2in SUs on original Healey manifolds and a bit of porting It was a former SCCA racer in the 60s and was great at WOT, but was probably getting a bit too much gas at lower speeds.
rjc157 said:is anyone out there running 3 hd8 carbs and what they used as far a manifolds
HealeyRick said:Here's an idea of what Hollywood Sport Cars went through to take advantage of triple HD8s back in the 60s: https://www.healey6.com/Technical/Dyno.pdf Unless you're planning on putting your car on track, 3 HD8s are likely to be overkill
