2500M Overdrive options
ralph_s
I'm looking for suggestions/ideas for overdrive options (or a 5 speed) for my 2500M. It has the stock TR6 drive train & I'd like to make it more highway friendly. Any thoughts & suggestions will be appreciated.
ps I'd like to keep the TR6 engine.
swift6
There are three options that I know of for a TR6. Depending on just how much room there is in the TVR all three should also work for you. One is using a Toyota based 5 speed with an adapter kit also which can be found hereHVDA Kit , another is a Ford T-9 kit that can be found at Quantum Mechanics and the last is using a T-5 transmission with a kit put together by Dupont Machining . I believe the T-5 offers the greatest range of choices in the overdrive gear.
V
vagt6
OF course, a Laycock J-type overdrive would be "correct" for your TVR, although I don't think TVRs came with OD.
Not sure if the longer OD gearbox would fit in the chassis, either. Anyone ever put OD in a TVR? :confuse:
Grantura_MKI
OD was an option starting with the 2500 Vixen. I have restored TVR's fitted with OD...makes a much better car to drive on freeways. Only difference is the Lucas relay fitted to the bulkhead near the steering column.
Cheers,
D.
R
ralph_s
Would you recommend the overdrive or a 5 speed conversion? Any advantage to either approach?
R
ralph_s
Agreed. Assume there is enough room to fit the unit w/o major modifications?
swift6
Shouldn't have to shorten the propshaft to use a J-Type. The mounting flange for the driveshaft should be in the same location. The OD replaces the tailhousing of the non-OD transmission. The OD and non-OD transmissions did use different mainshafts and getting all the parts to convert a non-OD transmission into an OD transmission can be time consuming and troublesome. The best and easiest bet is to buy an OD transmission complete. Are you sure the rear mount would even need to be changed? The mounts are the same in the TR6 in OD vs non-OD cars (they change between A-Type and J-Type OD's).
The advantage to a J-Type, other than keeping it closer to stock or at least a stock option, is that you can use overdrive in 3rd as well as 4th gear giving a 6-speed gearbox. The downside is that if the relay fails, which isn't uncommon, no more overdrive until it's replaced. Worse, if the overdrive is still engaged and you reverse the car, it will blow the overdrive clutches and it will need to be pulled and rebuilt. Luckily, there are options available out there to automatically disengage the overdrive whenever the transmission comes out of a gear into neutral so it can't be accidently left in overdrive.
Grantura_MKI
You maybe right about the propshaft, as I vehicles that I worked on where already fitted with an OD...just trying to think of things that may need to be sorted. I do agree that it is easier to purchase an OD already built, but the bits are about to buy seperatly.
The rear mount is a simple piece of flat stock.
I run three different vehicles fitted with a Laycock OD. One being my one ton tow vehicle. I never reverse with the OD engaged, bad habit with any OD. As far as the relay goes, the same relay is used on Jaguar's for horns and fans for many years.
The car will be a joy to drive if it has an OD fitted.
Thank you for your input, Shawn!
Cheers,
D.
R
ralph_s
I've got OD on my MGB and would not go without it. I'll probably go w/ the Laycock unit. Look forward to the conversion. I enjoy my 2500M and the OD will make it that much more enjoyable.
Thanks to all for the input.
Ralph
swift6
Glad to help anyway that I can, I always stop into this forum and read up. I still hanker after a 2500M every now and again.
Grantura_MKI
That is a GREAT motor! The best of every thing that TVR had...great fit at the doors and the body was at last built for every day use. Ralph, get to it! You will not reget the switch.
Cheers,
D.
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
C My 2500M progress/questions thread TVR 5
bravenrace WTB - TVR 2500M TVR 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
A 1974 2500M Spring Rates TVR 6
J Looking for a 2500M TVR 0
S 2500M or Vixen wanted TVR 0
B 77 2500M Shocks TVR 0
O TVR 2500m weatherstrip source needed TVR 2
J 1973 2500M ignition issue TVR 8
Z Just Restored 1973 TVR 2500M, Barn Find TVR 25
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
M TVR 2500M Triple Weber 40 DCOEs TVR 130
R 2500M Carb Conversion TVR 5
Jastx TVR 2500M tires - what are you running TVR 7
TRclassic3 2500M Heater cable TVR 1
TRclassic3 Flasher units 2500M TVR 3
Kirk_Fisher 74 2500M prices TVR 9
TRclassic3 2500M rear suspension TVR 5
TRclassic3 2500M sun visors TVR 11
Kirk_Fisher 2500M V8 on Ebay TVR 2
R 2500M Vents TVR 3
TRclassic3 2500M carpet kit TVR 1
R Windshield for a 2500M TVR 3
TRclassic3 Tranny removal 2500M TVR 10
R A fan of 2500M's!!! TVR 3
B 2500M chassis tube question TVR 2
R 2500M Cooling TVR 1
B 2500M search TVR 5
R 2500M Battery TVR 0
M TVR 2500M Model TVR 4
R Ignition Circuit - 2500M TVR 0
G Parting out a 2500M - Should I do it? TVR 18
Mickey Richaud 2500M on Ebay TVR 4
J TVR 2500M Shop Manual TVR 9
G 2500M hood TVR 3
G Gas tank for a 2500M TVR 5
H How to Remove Sunroof on 2500M? TVR 0
H How to Remove Sunroof on 2500M? Restoration & Tools 5
H Door Panel Removal on 2500M? TVR 4
H Photos of My 2500M's Engine and Radiator TVR 9
H Steering Column Binding in 2500M TVR 5
H 2500M Features and Stuff to Fix TVR 2
H Owners Manual for 2500M? TVR 3
H 2500M Came Originally With Electric Cooling Fans? TVR 19
H Bad Tach in 2500M TVR 0
AngliaGT 2500M on craigslist TVR 4
bravenrace Ebay 2500M race car and TR-6 Engine TVR 9
bravenrace 2500M Header Info Needed TVR 1
bravenrace 2500M on Ebay TVR 5
