Jim_Gruber
This was supposed to get started 3 weeks ago but finally found a few minutes tonight to complete Step 1) for Case Preparation. Relieving Bell Hosing flange to clear oil pump cover.
Not too bad actually. I used a 2 1/2 or 3"cutting blade on a Hi-Tech Harbor Freight Cutoff Tool. 1) Marked what needed cut and used the edge of the Cutoff Tool to create a 1 /4" Relief in the side of the case. Gerard's Adapter Plate on Tranny housing 2) Marked Area to be cut 3) Post Cutting 4) My expensive HF Case Modification tool .
Went slow and it took about 1/2 Hour to complete. Probably would have been easier and quicker with a Grinding Wheel but no such luck in the Grinding/Cutting Tool Drawer in my Garage. Will do a little more smoothing with Dremel and Rotary Sanding wheel but essentially done. Now to see how my new Camera does with close ups. Not too bad on the closeups. new Canon T6, my Christmas present. Next Step removing the Spine along the top edge of the case to clear heater shelf already done, most challenging part is drilling 3 1 3/4" Holes in the top of the case, along with Angle Grinder and SawZall to modify the case so it fits under the heater Shelf. Pics to follow.
View attachment 51483 View attachment 51484View attachment 51485View attachment 51486
