Deleted member 20746
First, I have the fuel pump off my 72 TR6 and note there are 2 thin grey rubber-like washers left over after putting it all back together (that were not on the original take off). They look to be the diameter of the pin that attaches the rocker arm to the engine. Are these to go inside the steel washers on either side of the pin to reduce oil leakage?? Any ideas?
Second, does the rocker arm attach in any special way in the engine upon reassembly? Thanks in advance for any help.
