scoutll said:
It seems like a lot, and I would be a bit leery about buying a rebuild off of ebay, but I'll bet if you checked with Hap and a few others, a quality rebuild of the type described on a 1500 would probably not be far off of 3000 including shipping ect.
Rest assured though, If I were going to spend 3 grand on a rebuild, It would go to someone with the references and reputation Hap has.
Actually, I would not do a stage 1 rebuild for that amount, it's a good thousand bucks short of what my stage 1 engines cost, and I'm not sure I could stay under $4k with a 1500, due mostly to quality parts cost for that engine.
This might sound like alot of money, but if you check with the West coast LBC hot rodders, you'll see I'm under the money, mostly because of the cost of living here in SC is lower, and I'm most competitve with professional LBC shop who do a variety of work, including engine rebuilding, but my engine are normally built to higher standards than the typical LBC shop, due to the fact, I don't work on cars, just build engines, heads and carbs, so it work I do mre frequently, everything is blueprinted and nothing chanced.
The Ebay engine, looks to have the proper machine work done, however I prefer using tri metal bearings in my engine, but overall, there is alot of work there. Things I do differently, I use APT nitrited cams and APT's rockwell 60 lifters, vernier timing gear set, ARP fastner (head stud kit, rod bolts, and flywheel bolts) I also use new valves , new valve spring, new bronze guides. I also spent a great deal of time in detialing everything, all engine sheetmetal, gets degreased, paint stripped, beadblasted, and then prime, paint and cleared indivdually, so when it's all bolt together, all the new fastner stand out, I hated theover spray bomb after assembly look, an nicely built engine should look the part. Heck, just cleaning everything, paint when applies, and getting it all clean, including block, head, rods, crank, you name it, is aprox. $500 of the build cost,and maybe the toughest part of the job.
