I've got a 1991 Ford Ranger and I think the wheel bearings are going. The front end rattles a lot and bounces all over. I finally got around to checking it out and for one I need shocks. Last changes at 70thou and now have 132. When I pull the top & bottom of the wheel it wobbles.
I had the entire wheel off to check the rotors awhile back and IIRC there is a large spring type nut inside the hub. Does anyone have any experience with these and do you need a special tool? I can't seem to figure it out.
It's a 4x4 in case you need to know.
