wingsandwheels
Hi All, want to confirm my understanding of the late MGB ignition and what coil I should be using. Interestingly I've found two different wiring diagrams for this car.
My new to me '79 has the original electronic ignition (external amplifier) but with the resistor wire and ballast resistor bypassed resulting in the coil getting the full ~14+ volts running. The coil is a 16c6 which is a 6 volt coil. I cannot (yet....haven't started unwrapping the blue tape) find the ~9v feed from the resistor wire from the main harness.
My inclination is to return the car to its original spec, figure the engineers had some good reason for what they did, but it is running so well that I am a bit hesitant to change anything. The engine was 'detoxed' by the PO's mechanic. I'd say DPO, but the work and the wiring changes appear to be carefully if not well done
My questions are:
Assuming I don't return it to original spec:
-Should I run a '12v' internally ballasted coil such as a Lucas DLB101 or Bosch Blue. Can't see the original coil taking full voltage, but it has lasted so far...
-do I need to run a resistor to the feed to the ignition amplifier? Seems to be getting full system voltage.
-any other thoughts
Thanks all.
My questions are:
-any other thoughts
Thanks all.
