Joe_Pinehill
Im trying to trouble shoot the horn circuit on my Spit. I bought a
new indicator/horn switch and installed. the button was broken on the
old, so i thought that might do it. But when i press the button, I
dont see voltage at the horn.
I jumped each horn directly to the battery , drivers side does not
work, passenger side does.
The headlight dimmer high beam works, which I think is also on the
purple bus.
Im thinking the easiest thing is to just run a new wire from batter
to the switch with an inline fuse, and another from the switch to the
horns, with trying to find out exactly where the problem is.
The hazard flasher also does not work Im thinking this may be related to no voltage on the purple wire?
Any tips on abandoning wires in place and running new?
purple bus.
Hi Guest!
