1978 MIDGET 1500cc engine oil leak
ARRIS
Good day,
My 78 1500cc is hemorrhaging motor oil 🤬. Are there any usual spots I should be looking for when trying to find the source? Secondly, I will be removing the pan so that I can replace the thrust washers that dropped into the pan. FYI, I recently purchased the car knowing that the previous owner had removed the pan and fished the TW out. My plan is to measure the crank play and order the TW from Scott Helms and install them with the engine still in the car. 🙏
With that said, if Ya'll can point me in the right direction regarding the oil leak it is much appreciated. Thank you in advance.
Darcy
JPSmit
you aren't running it with the thrust washers missing are you?
a couple of thoughts if it is leaking while the engine isn't running.
1. if the PO had had the pan off, he might not have properly put the pan or pan gasket back on - including overtightening the bolts and deforming the pan (don't ask how I know how easy that is)
2. If it is while the engine is running it could be that the PCV valve is clogged and it is blowing out the oil fill hole.
A
ARRIS
Hello, I have only started the car twice since I have purchased it. Did not use the clutch and or put it in gear.
I will have a better idea once I get her up on the Jack stands and have a dreamy gander at the undercarriage. Thank you for ur reply.
Darcy
JPSmit
good luck and keep us posted!
JMACENGINESHOP
Arris, as you probably already know, once the TW falls out there is nothing to prevent the rear thrust flange of the crankshaft from being shoved into the rear main bearing cap when the clutch pedal is pressed. If it goes very long without the TW that cap will begin to wear. Inspect it when you get the main bearing cap off; that cap is what keeps the TW in there. It creates a small ledge for the TW to rest on. If it is worn, even a little there will not be enough ledge to keep the TW in and it will fall out again. If it is worn the easiest solution is to weld some material to each side of the rear of the main bearing cap worn off by having no TW. You must make sure not to build this up too much. Weld, then practice fit the rear main cap to make sure it will not come in contact with the crankshaft flange. Also, some shop manuals say you should have .006" to .014" oil clearance on the TW and others say .006-.008". Both of these are too great, in my humble opinion. I try to get the oil clearance down to .004" to .006". This cuts down on the loss of TWs tremendously in the 1500.
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
L 1978 mg midget seat belt replacement Spridgets 3
R ?'s re 1978 Midget MG 3
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
J Windshield washer 1978 midget-bag on fender system Spridgets 0
J Firing order 1978 Mg Midget 1500 Spridgets 7
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
J 1978 MG Midget For Sale [florida area] MG 0
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
S MGB Newbie 1978 MGB questions MG 11
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
C MGB Radiator fans - 1978 MGB MG 11
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
regularman Its a 1978 and I want it. Spridgets 23
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
M MGB 1978 MGB Headlight Ring MG 8
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
M 1978 Eleectrical issues MG 17
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
D Trying to get back working on the 1974 Midget Spridgets 11
