Save some grief and get a couple line wrenches. SAE, 7/16" amd 1/2". A well stocked NAPA store will have individual ones. Likely better quality than these but if you intend to keep the MG it will come in handy. Likely you need not replace the steel line.
Double-End Metric Flare Nut Wrench Set, 5 Piece
Amazing deals on this 5Pc Metric Double-End Flare Nut Wrench Set at Harbor Freight. Quality tools & low prices.www.harborfreight.com
EDIT: The flex line may be 5/8" at the fittings, I don't recall.
If it is what I think it is, it is to hold it on the bracketThanks Doc! Any idea what the lock nut is below the tube nut? Things broke loose after tons of blaster. But I could feel the line and mechanism turn a bit above the flex hose while trying to break everything loose with a vice grip. Ugh!!!
has it worked? The reason I ask is that it took me almost an entire summer to sort my clutch a few years ago - NOTE it is a different line!!! - But what I finally realized is that my new clutch line wasn't seating properly hence the ongoing air issues. It wasn't seating properly because it was made of chinesium. I finally found a hose (again the Midget line is a plastic) and reused the original ends - finally fixed it. I find that there continue to be massive issues with a lot of the new parts being speced to the lowest bidder.Follow up: lots of air came out trying this method like the whole system is full of air.![]()
love it when a plan (finally) comes togetherGood news bled like back in the day; open, pedal down, close, pedal upā¦repeat. Just had to top off the master cylinder about every 1 or 2 bleeds, it holds soooo little fluid.
Thanks for the help!!!
