HI Everyone, I am a proud new owner of a 78mgb . I am far from being a car guy and do my best to repair as much as i can. This MgB has lots of little issues (mainly electrical) so I thought I would start with fuel smell in the compartment.
1. After reading great stuff on here, I believe I have found the problem. In the trunk on the right side near tail light is a silver canister. I'm guessing it might be a charcoal filter although in the pictures attached I thought the filter was up front. Anyway. I discovered all the tubing has rotted and was broken off. Can you please tell me what the hosing configuration is. Am I right in thinking that hose goes from tank up to canister (either entry?) then from canister to the silver vapor line? BTW I connect a hose to the main silver line and was able to blow through the line, which I am guessing is a good sign that there is no obstruction unless I shouldn't be able to?
2. the black canisters in the front of the engine, Is one of those also another charcoal?
Thanks so much in advance.
Marty
Marty
