BritDriver
Listed on BAT in 2023:
> 1978 Triumph Spitfire 1500 <
You can see photos and video there.
When acquired in 2018 I made these improvements, mostly immediately:
Steering/suspension:
- replace steering rack
- replace steering rack mounts with rigid type
- replace tie rod ends
- replace wheel bearings
- fit new RR axle
- replace axle pinion seal
- set toe and align steering wheel
- install new rear quad exhaust section,
- remove manifold, straighten header, grind flange to ensure leak free fit on head
- replace battery with premium Deka unit
- replace ignition switch
- New starter and solenoid
- replace RR brake shoes and wheel cylinder
- replace front brake hoses
- tune engine for performance
- replace u joint left rear
- replaced
