2wrench
AltaKnight said:2wrench....
You can see the "pick" points to lift the engine (and transmission together or seperate) on Toms pictures above, they are the 2 plates with a hole in them on the front left and right rear of the cylinder head.
If you're pulling it with the transmission attached then it will be a lot easier if you have a "tilting" device (you can see them in the on-line catalogs for Moss and TRF) to get the right angle (particularly on reinstallation)it can be done without but not easily.
Oh, and please be REAL careful as you're doing all this, that motor is not light, don't end up beneath it! make sure you're rigging gear is good and your spectators/helpers are sober.
Need a little more info on the "tilting device" from Moss.
Can't seem to locate such. Like to see one, though.
