TR6 1974 TR6 coil question
tdskip
Hi guys - would you recommend leaving the ignition set up as-is on an otherwise stock 1974 TR6 or would you go with a Lucas Sport Coil and by-pass the ballast resistor?
Thanks, and Happy Easter!
I have a Pertronix coil that is wired stock. I never got around to switching over to the Lucas Sport, which is sitting in my spares bin. If I ever do, I'll just swap the white wire Dan Masters trick so that it's not irreversible.
https://www.vtr.org/maintain/ballast.shtml
Same as Paul on my stock 74. Please be sure to read the link that Paul provided, especially the last couple of paragraphs about the relationship of spark plug gap to the high voltage coil. Even with the standard coil you can increase the gap to .035 and get reliable arc. I believe that this is due to an increase in dwell time with the Pertronix unit, allowing more voltage to develop in the standard coil.
Too much voltage from the sport coil just may cause more rapid deterioation of the rotor and contacts in the dizzy cap, as well
