BMCMidgetLover
I have a 1974 Midget, recently the engine was rebuilt. I have no oil pressure. I am going through it to understand why I have no oil pressure, but my engine does not have the pipe that goes to the filter head then to the block. There is no place to mount it. Because I took the oil filter off and the spark plugs out I was expecting oil coming out of the oil filter head, when the engine was turned by the starter but nothing came out. Therefore I believe my problem is most likely between the filter head and block, something like a plugged gasket.
Can I still take the banjo bolt out and prime the oil pump there?
Any thoughts or in sights would be appreciated.
Hi Guest!
