wkilleffer
Hello everyone,
It has been quite awhile since my last post. I've been rennovating the brakes on my 1974 MGB. This has been an interesting journey, and it took longer than I ever would have thought. Well, now the brakes are working again and it's time to get the car back on the road. There's just one problem...
The car's been sitting close to a year. I checked the battery voltage and the multimeter said it's at around 12.30v. I switched on the ignition, and didn't hear any clicking from the fuel pump. That said, the battery voltage was enough to crank the starter even though the car woudn't start due to no fuel in the carbs.
I then checked the voltage at the white wire on the fuel pump, and it says around 11.35v. That's with the meter set to VDC and grounded at the negative battery terminal. Is that enough power to get it going? I hooked up a jump start device to the battery to see if that might give it a little more juice, but no difference. The pump was almost new at the time I took the car off the road to do the brakes, and it was running then.
I was thinking about driving my old Jeep back to the garage and hooking up an old school pair of jumper cables since it tends to put out around 14v with the engine running.
Any more ideas? I'm trying to stay optimistic because it's at least getting some voltage, but I sure would have loved to have taken a drive today. It's a lovely 80 something degree low humidity day.
Thank you,
-Bill
Thank you,
-Bill
