MGB 1974 MGB convertible top anchor bar size
wkilleffer
Top frame's now installed and seems good, so now it's time to put the new vinyl hood on. This has been a long time in coming, so the piece of scrap metal I used to use for the anchor bar at the rear of the old top/hood has disappeared.
They're available in the catalogs, but I don't want to wait on a mail-order to get here or triple its cost by adding next-day air shipment. What is a good size for something like this? I've been told to use steel 1/8" thick and 1" wide, but not sure about the length.
Any assistance would be appreciated.
Thank you,
-William
Mickey Richaud
Platinum
Hey, William -
Just went out and measured mine; it's 35" long. Ends taper to a rounded point for inserting into the top pocket.
Mickey
wkilleffer
wkilleffer
Thanks, Mickey.
Think this is something I could get at the local Ace/Lowes/Home Despot? Probably get a slightly longer length so I can trim down the corners and make the ends round?
Mickey Richaud
Platinum
Probably can find some flat bar stock at the usual outlets. I would imagine they're available in 36" lengths, which would be perfect to cut down.
Mine is about the same, except that it's just rounded at the corners. Each end is flat with no sharp edges.
7 MGB My Project Car 1974 MGB Convertible MG 50
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
J MGB 1974 1/2 MGB gasoline type MG 5
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
wkilleffer T-Series Clutch pipe installation- 1974 MGB MG 2
N MGB 1974 MGB Questions MG 5
K T-Series Trailer Hitch for 1974 MGB Roadster MG 4
Monark192 MGB 1974.5 MGB vs. 1975 model. Which to keep? MG 19
wkilleffer MGB 1974 MGB distributor drive dog- which one is it? MG 8
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
wkilleffer MGB MGB 4-way fuse box question- 1974 MGB MG 8
C MGB-GT 1974 1/2 MGB GT MG 37
1 MGB 1974 MGB in Florida MG 15
M T-Series 1974 mgb ignition switch/lock w/harness MG 5
C MGB 1974 MGB ready for lots of work and help with questions:] MG 6
bravenrace 1974 TRV 2500M FOR SALE Other British Classifieds 0
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 5
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F MGB Correct steering wheel - 1974 MG 2
AngliaGT 1974 Midget - It's ALIVE!!! Spridgets 7
AngliaGT Early [11/73] 1974 Radiator Removal - Spridgets 4
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
T 1974 jensen healey Other British Cars 17
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
S TR6 1974 TR-6 project....I'm holding my breath and praying Triumph 13
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
D Found a 1974 Jensen Healey Spotted 3
aeronca65t Summit Point-1974 Racing 1
G TR6 1974 TR6 distributor advance spring specs Triumph 6
jsfbond 1974??? Triumph 3
M 1974 MklIII - inner chrome grill trim Spridgets 2
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
TR6BobNF TR6 1974 O/D TR6 For Sale in Newfoundland Triumph 1
I TR6 1974 tr6 Triumph 2
B 1974 mini part needed British Motor Corp 1
W TR6 Tr6 1974 Distributor Triumph 7
eschneider Morgan for sale: 1974 4-seater RHD 4/4 Other British Cars 3
