BoneIdle
Greetings all!
Work on the GT was suspended for a while due to a death in the family, but now I'm back at it.
I've had a problem with the battery draining totally to nothing for some time now. I had assumed that the battery had finally exceeded its service life, so I replaced it.
Although the old battery did test bad, the problem has recurred with a brand new battery.
Finally, I got off my lazy posterior and hooked up a test light between the positive battery post and the cable. I ensured that the key wasn't in the ignition and observed that the little test light was glowing.
I began pulling fuses, one at a time, and the light finally went out when I pulled the bottom fuse in the fuse box.
I can't find the cover for the fuse box, and I'm not sure that it would have this information on it, so what does that particular fuse control?
I tried a search on here, but I got bogged down pretty quickly, so I figured I'd just ask.
I do have a very good manual somewhere, but I'm still trying to locate it. When we moved from Iowa, the movers packed things too well.
Thanks. It's good to be back.
Garry
Garry
