TR6 1973 tr6 wiring
sundown
I am having trouble wiring my 73 TR6 do you have to have everything connected to get the blinkers and headlights to work Thanks
Gliderman8
I am thinking the ignition key has to be in the "on" position for the turn signals to work... I'm going from memory so I suggest you check the schematic to be sure.
Gliderman8
Check the grounds first...
poolboy
Yes, always suspect the grounds, but also....
lookng at the wiring schematic, the only thing I see those 2 circuits have in common is the headlight switch.
BillyB62
My 3A had problems with the turn signals earlier this year. As the forum peeps state, check the grounds.....worked for me :smile:
tdskip
Sundown, might be a good idea to explain exactly what is/isn't working. For example, no lights at all vs no flashers vs no turn signal etc..
hondo402000
on my 71 model the hazard switch is part of the turn signal circuit, I dont know if your switch is the same but the 71 has a rocker switch and if you go from hazard on to off and the rocker doesnt make full contact in the off position the turn signals wont work. As far as headlights, if they dont come on you need to start checking for power at the switch and trace it. Best I can offer you and yes clean all the grounds
did they work before and now they dont?
Hondo
Gliderman8
I had one headlight go out on my '73... I traced it to a bullet connector up near the radiator. Just cleaned it and chased Mr. Lucas away.
sundown
sundown
S.O.S on my 1973 TR6 I have the flashers working, headlights working, reverse lights working and the brake lights working. The turn signals NOT WORKING connections are right the blinker switch is good any help would be much appreciated I want to drive legal Thanks
Gliderman8
Have you checked the turn signal flasher located on the passenger side near the kick panel?
Are bulbs OK?
Next check the contacts in the bulb holders, they can corrode over time and might need to be cleaned.
Sounds like you are making progress!
TR3driver
Great Pumpkin - R.I.P
Er, you did turn the ignition on, right?
:crazyeyes:
Do the other "green" circuit items work when you turn the key on, like gauges, wipers, etc? If not, it's likely the fuse is blown, or could be the white wire from the fuse block back to the ignition switch or the green wire out to the hazard switch.
Assuming that works, I would probably check at the flasher next. If you pull the flasher out of its socket and check from each socket to ground (with the ignition on), you should find power on one of them. If not, the problem is likely to be the hazard switch itself. You can install a temporary jumper (short length of insulated wire with male quick connects on both ends, save for later use as well) to eliminate the flasher unit as a suspect and ease troubleshooting farther down the line.
If still no joy, I would double-check that the 3 GW and 3 RW wires are joined together (where the turn and hazard circuits meet to run out to the bulbs). It's unlikely both connections are bad, but since you are installing the wiring ...
Next, I'd pull the turn switch out and check directly at it with it still connected. With the jumper installed at the flasher, you should see a constant 12v coming in, and 12v going out to whichever side is selected. Sometimes a switch will check fine with an ohmmeter, but not be able to carry enough current to actually light the bulbs.
After that, you just continue to divide and conquer along whichever segment shows what it should on one end, and nothing on the other end.
sundown
sundown
yes all my gauges are working, the heater blower is good, and wipers working, but shouldn't the flashers work without the key turned on they only flash when the key is on thanks for the input
TR3driver
Nope, the turn signals only work with the key on. Hazard flashers work either way, but not turn. Dunno why, but that's the way it is on every car I've ever owned. Part of the reason that circuit is so complicated.
sundown
sundown
ok so the flashers should work off the battery w/out any power from the ignition? are the bulb socket holders part of the grounding process
TR3driver
I don't quite understand the question. The turn signals get their power from the ignition switch (meaning the switch has to be on for the turn signals to work). But the engine does not have to be running (meaning the battery is the ultimate power source and the ignition switch only passes it on).
Yes, the bulb sockets provide the ground connection to the bulbs. With the original rear sockets, it is very common for the plastic body to droop and lose the connection inside the socket. See https://www.buckeyetriumphs.org/technical/Electrical/TR6Sockets/TR6Sockets.htm for one way to deal with the problem. (The ones on my Stag were so bad that I actually had to use a short length of wire to bridge the gap.)
mrv8q
If you haven't already, it's easy to completely disassemble and clean the fuse holder, good PM.
sundown
sundown
My question or I should say my problem is the emergency flashers should work with the ignition off using only the battery for power and the brake lights should also come on when hitting the brake pedal with out the key position on .They only work when I have the key to the on position also the brake light bulb was super hot after being on for about 3 mins?
TR3driver
The brake lights also do not work without the ignition on, as original. That seems to be a British convention; all the British cars I've looked at work that way, while most American cars have the brake lights work without the ignition being on.
Yes, brake light bulb will be very hot after 3 minutes of operation. Incandescent bulbs contain a small amount of inert gas, which greatly extends the life of the filament; but also conducts some of the heat from the filament (which is somewhere around 5000F when lit) to the bulb.
sundown
sundown
That's great info about how hot the brake bulb can get since I have a blister the size of a a quarter.Can't believe the glass bulb doesn't burst. But back to the emergency flashers they should operate w/out the key on? They only work with the key to the on position. Thanks for all the help
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
R TR6 1973 Final drive issues Triumph 5
K 1973 MGB for sale MG Classifieds 0
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
Boink 1973 Marcos MINI Spotted 1
