Hi. New to the forum. Picked up a ‘72 midget, 1275cc rebuild a while back. Engine started dragging and recently died. Turns out two of the cylinders have excessive pitting and I am no longer getting compression. First option is a machine shop...curious if others have experience or advice in this space. Many thanks in advance.
. Picked it up ~2500 miles ago...ran beautifully...about a month ago, the fuel pump went...no issues replacing. The following week it started to ‘choke’ as i was driving...would bog down and then catch and run even again. Finally it died. Rebuilt the carbs...pulled the shafts (felt like it was taking on air). Finally brought it into the shop...he pulled the plugs/gaskets and looked down the Cylinders...said two had no finish with significant pitting. His recommendation was finding someone to do the honing...sounded like bottle brushing or the like was off the table. Now we are trying to find a shop that would be willing to do it. Anything to look out for if we were to move forward with machining the two cylinders? Thanks again
