UltimateQuestion
Everyone says they are looking for a project – well here it is! I need to let my 1972 GT6Mk3 project go, I just don't have the time, the money and the skills necessary to complete it and I'm not getting any younger. The car was Damson Red with a black interior, it is a rotoflex rear suspension, no overdrive. This is a PROJECT and needs someone who can appreciate what the finished car will be like. I do have a clean title for the car and all the keys. I have started on disassembly and stripping the paint and filler off the car. The floors and sills need replacement and the rear wings are rough, but the frame is good and the drivetrain should be OK, turns over by hand although it hasn't been started since the late 1990's. Transmission and shifter were rebuilt in the past. So I am offering for sale the semi-disassembled car that needs a lot of body work, along with at least $8,000 - $10,000 in mostly new parts I have collected over the years. Included is all the sheet metal needed to complete the repairs – new rear wings, complete passenger and driver side floors, inner & outer sills, and sill strengtheners. I will also include a reprint factory service manual, factory parts catalog, and several other repair & restoration publications. A list of the parts is below. I'm not interested in parting out, you will have to come with a trailer and collect the whole lot. The car is located in Northern Virginia, and I am open to reasonable offers, looking for around $4,000 for the car and parts. I have seen cars that are worse than mine sell for more. And they don't come with all the parts. Someone could make this into a fantastic car. Make me a reasonable offer
Parts included with the car (new unless noted)
Rocker End Cap - LH
Rocker End Cap - RH
LH Inner Sill
RH Inner Sill
LH Inner Rocker Panel
RH Inner Rocker Panel
LH Outer Rocker Panel
RH Outer Rocker Panel
Rear Wing, LH
Rear Wing, RH
Main Floor Panel, LH
Main Floor Panel, RH
Peg, Bonnet Locating - 2
Strip, Rubber, Bonnet Protector - 2
Bonnet Hinge Bolt - 2
Bonnet Hinge Nut - 2
Rivet, Check Strap Guide Spring - 2
Rubber Boot, Check Strap - 2
Rivet, Check Strap - 2
Door Check Strap - 2
Door Hinge - 4
Chassis ID Plate
Front Spoiler, Plastic
Spoiler Mounting Hardware Kit
AMCO Rear Bumper Oreverider Bar - Used
Rear Finisher "Horseshoe" LH Black
Rear Finisher "Horseshoe" RH Black
LH Headlight Panel - NOS
RH Headlight Panel - Used
Front Marker Light LH - Used
Front Marker Light RH - Used
Headlight Rim - 2, Used
Headlight Bucket - 2, Used
Bonnet Latch - 2, Used
Bonnet Prop Rod Assenmbly - Used
Bonnet Brace Tube - Used
Bonnet Strength Brace - Used
LH Bonnet Hinge Tube - Used
RH Bonnet Hinge Tube - Used
Washer Jet Assembly - 2
BL House Badges - 2
Door Handle Set - Chrome with keys
Front Valence Bonnet Seal - 2
Rear Bonnet Seal
Sill Weatherstrip - 2
"A" Post Weather Strip - 2
Windscreen Seal
Headlight Gasket - 2, Used
Petrol Filler Cap Gasket - Used
Gasket Set, Wheel Arch
Door Handle Gasket Set
Felt Seal, Oil Dipstick,
Gasket, Fuel Pump to Block
Oil Filter Element
ROTOFLEX Couplings - 2
Bolt Kit, ROTOFLEX
Halfshaft U-Joint - 2
Valve Cover Gasket
Driveshaft U-Joint - 2
Fan Adaptor/Damper
Fan, Plastic (USA Only)
Fan Bolts
Fan Adapter Bolts
Fan Belt
Radiator Bypass hose
Radiator Bottom Hose
Radiator Top Hose - 2
Thermostat, Summer
Thermostat Housing Gasket
External Oil Feed Kit
Filter Cooler Adapter Kit, SS Hoses
Radiator, Oil Cooler, 13 Row
Cable, Heater Water Valve
Sleeve, Cable Water Valve
Headlight Switch, Lucas
Ash Tray
Radio Block Off Plate
Dash Fascia, Wood, 3 Piece - Used
Trans Tunnel, Plastic
Trans Tunnel Hardware Kit
Trans Tunnel Seal Kit
Standard Carpet Set
Luggage Floor Carpet
Rubber Floor Mats
Spare Wheel Clamp Disk
Spare Wheel Hook Bolt
Spare Wheel Wing Nut
Window Crank - 2
Upper A Arm Bolts - 4
Lower A Arm Bolts - 4
Lower A Arm Nuts - 4
Upper A Arm Nuts - 4
Grease Fittings - 2
Steering Rack Gaiter RH
Steering Rack Gaiter LH
Steering Rack Mounts 2
SPAX Adjustable Dampers, Front - 2
Lower Shock Bolts - 2
Lower Shock Nuts - 2
Wheel Bearing Kit, Front Hubs
Sway Bar Bush Kit, Poly
Sway Bar Mount & Bush Kit
Steering Column Bush Kit
Rear Suspension Bush Kit
Radius Arm Bush - 4
Innner Wishbone Bush - 2
Outer Wishbone Bush - 8
Outer Wishbone Water Seal - 8
Outer Wishbone Spacer - 8
Outer Wishbone Dirt Seal - 8
Outer Wishbone Nuts - 2
Rear Wheel Bearing Kit
SPAX Adjustable Dampers, Rear - 2
Upper Shock Nuts - 2
Radius Arm Bolts - 4
Brake Pad Retaining Kit
Semi-Metalic Brake Pads, Set
Anti-Squeal Kit
Brake/Clutch Pedal Return Spring - 2
Pressure Warning Switch
Boot, Pedal Brake/Clutch - 2
Stainless Steel Brake Hose Kit
Copper Nickel Brake Line Kit
Girling LMA Brake Fluid
Rocker End Cap - LH
Rocker End Cap - RH
LH Inner Sill
RH Inner Sill
Rear Wing, LH
Rear Wing, RH
Door Hinge - 4
Chassis ID Plate
BL House Badges - 2
Rear Bonnet Seal
Windscreen Seal
Oil Filter Element
Bolt Kit, ROTOFLEX
Valve Cover Gasket
Fan Adaptor/Damper
Fan Bolts
Fan Adapter Bolts
Fan Belt
Thermostat, Summer
Ash Tray
Standard Carpet Set
Rubber Floor Mats
Window Crank - 2
Grease Fittings - 2
Radius Arm Bush - 4
Anti-Squeal Kit
