TR6 1970 TR6 Timing Question
Pete22
This is the first time I will be tuning my newly acquired TR6.
I was ready to pull out my timing light when I read (from several posts) that a 1970 TR6 should only be timed statically.
Any input around which method (static or dynamic) should be used is greatly appreciated.
Thanks.
Pete
I set the timing on my 71 tr6 22 years ago and have never needed to adjust it in the years since. I used a timing light and some chalk on the lower pulley and didn't bother statically timing it. You can also check your advance when you rev the engine.
