General TR 1967 Triumphm 2000 no ignition
AH67
Hello All,
I just had a major tune up done at a local shop for my 67 2000 and had a Pertronix ignition installed. Car ran great for a while but after coming back from a vacation with the kids she would not fire up, turn or ignite. Battery is good (lights, radio and all) and ignition was not on while the car was parked.
Any help would be greatly appreciated
DavidApp
Does it have the rubber covered plunger on the starter solenoid? If it does press it to see if it will turn. If oit turns you may have a blown fuse.
David
TR3driver
Great Pumpkin - R.I.P
You're saying the engine won't crank at all, right? Are there any other noises when you try, clicks or clunks? Do the lights dim when you turn the key?
If there is no reaction at all, I would try connecting a test light or DMM from the side terminal on the solenoid (with the WR wire) to ground and try it again. If the light comes on (DMM shows voltage), probably the solenoid is bad. If not, I'd suspect the ignition switch. I don't have a book handy, but I don't think there is a fuse in that circuit.
bobhustead
Shade tree diagnostics says jump across the big poles of the solenoid with a plier and see if the starter turns. Then jump from the batt terminal of the solenoid to the terminal with the WR(little) wire. The WR wire is energized by the starter button or start position of the switch. Randall has you looking for voltage that should be in that wire when the start button or start position of ig switch is engaged. The solenoid is just an electromagnet that pulls a lug directly across the two big poles, as I am suggesting with the plier. If it doesn't work with the direct jump and you have a hot battery, probably a starter issue. If it then doesn.t work jumping from the batt to the little (WR) terminal on the solenoid, it is probably the solenoid. If no power gets into the little wire when you activate the starter switch, it's the little wire or the switch.
TR3driver
That will work, but the downside is that if you don't get really good contact on both posts, it will damage the posts. Sometimes you do what you've got to do, but to me it's a last resort. You can buy a cheap DMM and test light both for less than what one of those solenoids costs.
https://www.harborfreight.com/7-function-digital-multimeter-90899.html
https://www.harborfreight.com/circuit-tester-30779.html
AH67
AH67
thank you all. jumped across the big poles of the solenoid and fired up right away. The solenoid was the problem here
AH67 General TR 1967 Triumphm 2000 Triumph 7
T MGB-GT cant rails on 1967 MGB GT MG 12
AUSMHLY 1967 Mark III, Phase I through III and counting Austin Healey 38
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
C Spitfire 1967 Triumph Spitfire Triumph 2
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
mch979 1967 MGB GT bonnet issue MG 25
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
S For Sale Triumph TR5 Factory Parts Manual on CD/ROM - 1967 to 1968. Triumph Classifieds 0
S For Sale Triumph TR5 Factory Workshop Manual on CD/ROM - 1967 - 1968 Models. Triumph Classifieds 0
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
M MGB 1967 MGB seats MG 9
T 1967 BJ-8 Kick Panels Austin Healey 1
G For Sale 1967 bj8 Austin Healey Classifieds 0
longbridgehealey 1967 sprite earth? Spridgets 12
S New Member 1967 Austin Healey 3000 Austin Healey 5
H 1967[?] Austin FX4 London Taxi Other British Cars 3
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
F For Sale Beautiful 1967 Triumph Bonneville T-120 Triumph Classifieds 1
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
G rear wheel studs on my 1967 BJ8 Austin Healey 5
R Rewiring a 1967 3000 Austin Healey 17
M Overdrive In-Op AH BJ8 1967 Austin Healey 11
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
M TR5/TR250 Where were you on this day in 1967? Triumph 19
Sopwith_Camel was this wire brown in 1967? Jaguar 5
D Need Some Advice on My 1967 BJ8 Austin Healey 8
Marvin Gruber 1967 BJ8 out of the barn Austin Healey 8
Rut TR4/4A 1967 commission number decoding Triumph 16
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
S 1967 3000 MK3 BJ8 Suspension is so stiff - any chance to improve comfort ? Austin Healey 10
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
A 1967 BJ8 Coupe based upon the ACME advert Austin Healey 74
Stewart MGB-GT Next Project 1967 GT MG 139
sjuengst 1967 BJ8 on Austin Craigslist Austin Healey 2
G MGB Sick 1967 MGB Engine MG 1
G K&N air filters for 1967 BJ8 Austin Healey 6
C TR4/4A 1967 TR4A IRS motor mounts Triumph 7
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
Stinger TR4/4A 1967 Triumph TR4-A FOR SALE Triumph 9
Keoke 1967 BJ8 for sale Austin Healey 0
