1967 Sprite started to sputter /hesitate...help?
Stoney
Hi guys, I am a new member... A fellow owner directed me to this forum. I have had a rebuilt 1967 1275cc Sprite for around two weeks. The car has been gone through. It has run fine until today, while coming back home it started to sputter, knock almost cut off then lurch back into firing. This happened in all forward gears. I use only high-test gas, and the oil, filters, etc. are good. New Coil and plugs and points... Any ideas out there before I chance going to a Euro-Tech mechanic (If I can get the car there?) Thanks, Stoney
Billm
Re: 1967 Sprite started to sputter /hesitate...hel
Sounds like a bad condensor to me. Cheap to try and remember that even brand new ones have been known to be bad so if you just changed it with the points it still could be bad.
Bill
spritenut
The new india made rotors are junk in a box too.
2 weeks is about their life expectancy.
You might have a clogged gas cap vent.
When it dies, remove the gas cap, if you hear a rush of air, get a new cap or just slice the rubber gasket.
Fuel in the float bowls might be low.
Fuel pump dying? Do you hear it ticking when you turn on the key?
S
Stoney
Thanks guys... I do hear the fuel pump okay, and the gas cap is okay. I may try the condensor...
RobSelina
check the vent line on the carb for obstructions too, but based on your description and the similar experiences of others, my money is also on the condensor!
S
Stoney
Well guys, I changed the condensor, coil, and fuel filter... still eratic. I'm moving on the points, and Lord help me... the Webber Carbs. Any things to remember if it goes to the carbs? Thanks, Stoney
RobSelina
oh you have webbers? well that's the problem! /ubbthreads/images/graemlins/laugh.gif
regularman
You have more than one weber carb? Do a bit of troubleshooting. Is the misfiring on an one or two cylinders only? or is it irratic as in any cylindr at any time? If you have a weber, check the fuel filter screen that screws into the carb where the gas line comes in. It unscrews with a wrench and has a brass filter media similar to a oil furnace nozzle screen.
It's either spark or fuel, all advice above is solid, we tend to give advice based on our last problem experienced, so I'll add this, check the timng if the distributor clamp was left loose the timing will retard itself, make the car, spit sputter and slow to crank, if it does crank at all. When you get the car timed properly if that is the problem, take a permanent marker and put a mark index mark on the distributor and clamp, so if it ever moves again, you know it, also if you ever have to pull the distributor for any reason, you've got a quick reference of where to re-install it.
S
Stoney
Thanks guys...good advice. A friend of mine who is a lot better on points is coming over. I figure with all that I have done, and points/timing... that leaves the carbs. By the way...a fellow told me they made a bolt on fuel injector set up to boot with a Webber mount? Does anyone know if this is true? Thanks, Stoney
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
longbridgehealey 1967 sprite earth? Spridgets 12
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
J Free 1967 Sprite MG 1
J Free 1967 Sprite Triumph 4
J Free 1967 Sprite... Spridgets 9
Westfield_XI Pictures of Westfield 11 formerly a 1967 Sprite Spridgets 17
T MGB-GT cant rails on 1967 MGB GT MG 12
AUSMHLY 1967 Mark III, Phase I through III and counting Austin Healey 38
C Spitfire 1967 Triumph Spitfire Triumph 2
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
mch979 1967 MGB GT bonnet issue MG 25
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
S For Sale Triumph TR5 Factory Parts Manual on CD/ROM - 1967 to 1968. Triumph Classifieds 0
S For Sale Triumph TR5 Factory Workshop Manual on CD/ROM - 1967 - 1968 Models. Triumph Classifieds 0
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
M MGB 1967 MGB seats MG 9
T 1967 BJ-8 Kick Panels Austin Healey 1
G For Sale 1967 bj8 Austin Healey Classifieds 0
S New Member 1967 Austin Healey 3000 Austin Healey 5
H 1967[?] Austin FX4 London Taxi Other British Cars 3
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
F For Sale Beautiful 1967 Triumph Bonneville T-120 Triumph Classifieds 1
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
G rear wheel studs on my 1967 BJ8 Austin Healey 5
AH67 General TR 1967 Triumphm 2000 no ignition Triumph 5
AH67 General TR 1967 Triumphm 2000 Triumph 7
R Rewiring a 1967 3000 Austin Healey 17
M Overdrive In-Op AH BJ8 1967 Austin Healey 11
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
M TR5/TR250 Where were you on this day in 1967? Triumph 19
Sopwith_Camel was this wire brown in 1967? Jaguar 5
D Need Some Advice on My 1967 BJ8 Austin Healey 8
Marvin Gruber 1967 BJ8 out of the barn Austin Healey 8
Rut TR4/4A 1967 commission number decoding Triumph 16
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
S 1967 3000 MK3 BJ8 Suspension is so stiff - any chance to improve comfort ? Austin Healey 10
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
A 1967 BJ8 Coupe based upon the ACME advert Austin Healey 74
Stewart MGB-GT Next Project 1967 GT MG 139
sjuengst 1967 BJ8 on Austin Craigslist Austin Healey 2
G MGB Sick 1967 MGB Engine MG 1
