1967 BJ8 Tire Size
bowilli3
Hello,
I am trying to find new tires for a 1967 AH 3000 BJ8. The original tires are size 165-SR15. I have been told by a salesman at TireRack that these are equivalent to 165-80/15s. Has anyone tried this size tire? Are they approximately the same size? The car has the original 5.5 x 15 wire rims.
The only tire that Tire Rack has in that size is a Kumho Power Star 758. I am not familiar with this brand. Does anyone have any experience with these tires?
Thanks for your help.
Bo
Dave Russell
Yoda - R.I.P
Hi Bo,
Welcome to the forum.
Tire selection is a personal preference item. People have their own widely varying opinions about size, profile, & cost. Kind of like "which toothpaste is the best"
The original tires were 5.90/15 bias ply tires. the wheels should be 4.5 x 15. The 165R15 tires that are widely available, they fit old VW's, vary in aspect ratio from 80 to 85. Most of them are a bit smaller in diameter than the original 5.90 bias plys.
Since there are so many different opinions, I won't attempt to suggest a specific tire & size. Many folks use something like 185 to 200 - 70R 15's. If you get tires that are too large, they will rub on something when turning or cornering. Reports on which tires rub also vary widely. I replaced a set of Michelin 175R-15's with Gillette 165-82R 15's & there isn't much difference except the Gillette's were about half the cost of the Michelins which were no longer available.
I'm sure that others will report their favorites.
Good luck,
DerekJ
Bo
AS Dave says the original rims are 4.5 not 5.5 although a PO may have fitted wider wheels to your car. If so 165 may not be wide enough. I'm not sure as I stick to the original 4.5's.
Regarding the profiles the Tirerack guy is not too far out. By comparison I just fitted the Vredestein Sprint Classic designed specially for Classic cars. The profile is 86.
i.e 165*86*15. Thats getting pretty close to the original bias (cross) ply tyres which were I think very slightly higher than that in profile
Wana
Hi Bo,
I recently purchased a set of Vredestein Sprint Classic 185/70's from British Wire Wheel. They look great on my '66 BJ8 and they ride and handle very well. I know Hendrix Wire Wheel also sells tires, you might want to check them out as well. Both have good web sites.
Wana
ron wilson
Have 165R15s on my 66 BJ8 and they work fine Bought them from Les Schwab's They are called Jupiter's made in Korea.
Have been on the car for several years.
Bot a 59 TR3 about 2 years ao and it had the exact same tire on it.
Keoke
[ QUOTE ]
Hi Bo,
Wana
[/ QUOTE ]
BO, /ubbthreads/images/graemlins/iagree.gif The 185X70X15 tire size is as good as it gets on the BJ8 cars. However, this size tire for some reason is very difficult to find except for the Vredestein brand mentioned. I have been running them on my cars for years now and have no complaints---Fwiw---Keoke
P.S.The Tire Rack Man was also correct.
DerekJ
Keoke
Just looked again on the Vredestein web site. The 70 in the 185/70 doesn't I think, refer to the profile which is listed as 89. Not sure what the 70 is as there is also also a 185 Sprint Classic without the 70 and which also has a profile of about 90
Andrew1
I just replaced an aging set of Michelin 175 R 15 which were perfect tires... and not as bulky looking in the wheel wells like the 185 + that I've seen on other cars. Another poster correctly identified they went out of production a few years ago... too bad (Cooker should pick up the mold!)
But, Coker had a large batch of 175 R 15 by Bridgestone at a super low price of $49 each. They look a bit taller and thinner than the Michelin's. I've used them for about 2000 miles and they seem to be fine, with a tad less grip than the Michelin's they replaced.... For the price, I like them.
-Andrew -
Keoke
HI Derek. You have to be careful because the 185/15 tire is a Jaguar tire much too large for the healey.I am not up on all these profile numbers I see extending the standard 80 series.--Fwiw---Keoke
GregW
Platinum
If I recall correctly, the diameter of the original tire is 26”. Whichever tire you go with, you may want to stay close to that figure so your speedometer will still be accurate… Or not. There are adaptors available. I went with 205/60 16’s which have a 25.7”diameter, but they may be a little loose on stock wire wheels. /ubbthreads/images/graemlins/devilgrin.gif
KevinR
DerekJ
The 70 should equal the aspect ratio of the tire.
If a tire does not have an aspect ratio in the size it is an 82. (82% as high as it is wide)
Here is a quick calc for OD. of a 185/70R15, 185(width)/25.4 to convert from MM to inches x 70%(.7)= 5.098 inchs tall. x 2 because there is a top and bottom = 10.196 + 15(wheel diamiter) = 25.196" overall diameter.
The 89 shown at the end of the size is the Load index. most tires have this now but it is still farily new. an 89 load index says the tires max load carrying capacity at max inflation pressure (36) is 1276 pounds.
Kevin R
1960 BN7
DerekJ
Thanks Kevin. /ubbthreads/images/graemlins/thumbsup.gif This is starting to make sense now. This would explain why the wider 185 tyre has a 70% ratio compared to the 165 which has 82%. Otherwise the wider tyres would be higher than normal.
vette
Bo, just to give you another example, I am running a 165R15 Cooper tire on my BJ7. Its outside inflated diameter is approx. 25 1/2 inches. Another fellow i know is running 185's on his 100/6 and they rub on occasion on the frame rail.
Greg, did I understand you right that you are running a 16" wheel on your Healey. If that is correct, /ubbthreads/images/graemlins/cool.gif, can you tell me what wheel you are using and what it took to make it fit.
Thanks, Dave C.
GregW
Platinum
Hi Dave,
Yes, Alan at Hendrix Wire Wheel helped me get some custom wire wheels. They are 16”x6” 72 spokers. Personally, I like the look of a lower profile tire, but I wanted to stay with the original diameter. I also have a wider choice of tires to choose from now. The downside was I had to flare the fenders a little. I’m not a big fan of the abrupt flare that the Sebring kits have, so I tried to come up with something a little subtler. This shot is a work in progress.
vette
Greg, the objective of running a lower profile tire is something that I would like to do too. your work in progress looks pretty good, I'm sure it will improve the handling as well. If you're maintaining the same overall diameter of the combination wheel and tire, why do you have to flare the fender. Unless you've gone wider as well?
Thanks, Dave C.
GregW
Platinum
Hi Dave,
I think this picture will explain the need for flaring. You can also see the diameter is almost identical. I wanted to get the tires before I did the bodywork so I could match the two elements without any guesswork. Alan and I worked it out so the inside of the tire is in the same space as the original so there shouldn’t be any rubbing on the inner fender in a turn. Apparently these rims raised a little commotion at his shop. When a customer found out what they were for, he said “ I didn’t know they made 16” wheels for a Healey” to which Alan replied, “We do now”. /ubbthreads/images/graemlins/devilgrin.gif Dayton increased their prices by about 20% almost a year ago. I was able to order my rims two days before that (wheeoo). Just a warning about possible sticker shock.
stever
Bo,
I am currently running the Kumho Power Star 758 tires and am pleased with them. However, I would go with a little wider tire the next time as I have the minilite reproduction alloy wheels that are wider than stock and the 165's are a little thin. They drive well and are very inexpensive. I like the wet road handling, too. If you have the funds you should consider sending your wheels to Hendrix Wire Wheel and have the wheels inspected for true and have the tires mounted there. They will shave the tires to true round, balance, etc. for a great ride.....also, if you happen to have the typical 55mph "bounce" or "shake", balancing your rear wheel brake drums will possibly take that out - did for me! Good luck!!!
SHG
Just a heads up. I was trying to find 165SR15s at Tirerack to patronize the fine people who support BCF. Unfortunately, I couldn't find any 165/15s there. So I searched a bit and found Vredesteins at tiresunlimited, with all the various classic sizes that work for our LBCs. Price and ship were very low (less than Coker and BWW), and had the tire at my door in 2 days. I would like them to advertise here, though I'm not sure if Basil would have 2 tire dealers at the same time. But if you can't find what you need at tirerack, they are worth a try.
B
BUNDYRUM
Hello GregW, i like that flare on the front fender it looks most beautiful. Did you or are you going to try and copy it for the rear? On my BN1 i had 205/75R15 and with the 2 deg of negative camber at the front it moved the top of the tire inwards which cleared the fender. That was 20 years ago and i don't remember them rubbing anywhere on the front and probably didn't care about them rubbing on the rear. I had fitted fiberglass fenders front and rear so was able to open out the wheel arch of the fenders to give more room. Ahh the things we did back then. My BN7 has 205/70R15 Pirelli P4000 and i had the front fenders flared a little bit by a bodyshop (not even as much as you have) but it did allow enough clearance at the front. With the rears i put a 3/16ths spacer between the drum and the spline but it still rubs but i don't seem bothered by it. I have other plans for it in the future so at the moment i put up with it. Regards, BUNDYRUM.
G For Sale 1967 bj8 Austin Healey Classifieds 0
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
G rear wheel studs on my 1967 BJ8 Austin Healey 5
M Overdrive In-Op AH BJ8 1967 Austin Healey 11
D Need Some Advice on My 1967 BJ8 Austin Healey 8
Marvin Gruber 1967 BJ8 out of the barn Austin Healey 8
S 1967 3000 MK3 BJ8 Suspension is so stiff - any chance to improve comfort ? Austin Healey 10
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
A 1967 BJ8 Coupe based upon the ACME advert Austin Healey 74
sjuengst 1967 BJ8 on Austin Craigslist Austin Healey 2
G K&N air filters for 1967 BJ8 Austin Healey 6
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
Keoke 1967 BJ8 for sale Austin Healey 0
J BJ8 1967 Carpet install under convertible frame Austin Healey 3
P Throttle linkage on 1967 LHD. BJ8 Austin Healey 5
7 Lacquer Paint for a 1967 BJ8 Austin Healey 14
T MGB-GT cant rails on 1967 MGB GT MG 12
AUSMHLY 1967 Mark III, Phase I through III and counting Austin Healey 38
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
C Spitfire 1967 Triumph Spitfire Triumph 2
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
mch979 1967 MGB GT bonnet issue MG 25
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
S For Sale Triumph TR5 Factory Parts Manual on CD/ROM - 1967 to 1968. Triumph Classifieds 0
S For Sale Triumph TR5 Factory Workshop Manual on CD/ROM - 1967 - 1968 Models. Triumph Classifieds 0
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
M MGB 1967 MGB seats MG 9
T 1967 BJ-8 Kick Panels Austin Healey 1
longbridgehealey 1967 sprite earth? Spridgets 12
S New Member 1967 Austin Healey 3000 Austin Healey 5
H 1967[?] Austin FX4 London Taxi Other British Cars 3
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
F For Sale Beautiful 1967 Triumph Bonneville T-120 Triumph Classifieds 1
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
AH67 General TR 1967 Triumphm 2000 no ignition Triumph 5
AH67 General TR 1967 Triumphm 2000 Triumph 7
R Rewiring a 1967 3000 Austin Healey 17
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
M TR5/TR250 Where were you on this day in 1967? Triumph 19
Sopwith_Camel was this wire brown in 1967? Jaguar 5
Rut TR4/4A 1967 commission number decoding Triumph 16
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
