1967 Austin Healey Sprite (MG Midget) "Spridget" Race Ready $14,950
Price includes everything listed in this ad and more.
Over $6,530 in NEW parts included in sale price.
Recently Rebuilt Engine with less than 200 miles
Clear Colorado Title
This small bore production race car is ready to enter the next vintage race event.
Owner will deliver it anywhere in CONUS for actual costs.
Owner will trailer it to any track within 100 mile radius of Denver to test drive on track day or your entry on race day.
Rocky Mountain Vintage Racing (RMVR) logbooks with 2024 annual inspection.
NASA Technical Inspection (meets NASA roll cage rules)
1200+ CC
NEW Alloy Wheels 5" x 13" Minator silver 8 Spoke Set of 4 $500
NEW Toyo R888R 185/60R13 with road force balance set of 4 $800
Used Minator spares Wheels w/tires set of 4
NEW Intake Maniflow Manifold 7" A-SERIES INLET (LI53SP) $300
NEW Exhaust Maniflow Ceramic Coated Manifold MIDGET STAGEIII L/BORE LCB EXH MANIFOLD (CLM033III) with AFR dongle $400
NEW Maniflow Reverse Cone Megaphone muffler $100
NEW Weber 45 DCOE $800
NEW Heavy Duty Manifold Gasket and at least 3 spares $40
NEW Throttle linkage $60
NEW Carburetor Heat deflector $20
NEW Weber Tuning Jet Set of 10 or more sizes with two sizes of Venturis $150
NEW Throttle Cable $20
NEW Maniflow Intake Carb Stacks $20
NEW MSD Ignition DISTRIBUTOR 8485 $500
NEW MSD Digital 6CT Ignition Controller 6427 $500
NEW MSD Spark Plug wires $60
NEW 4 Sets of 4 of various heat range sparkplugs $40
NEW Front Steering Assembly $100
NEW Tie Rod Ends $90
NEW Fuel Cell $300
NEW Fuel Pump $100
NEW Radiator Four Row Aluminum $140
NEW Shocks Front and Rear $200
NEW Electric Fan for radiator $100
NEW Steering Wheel $150
NEW Steering Wheel Quick Disconnect $30
NEW Starter $100
NEW Crankshaft light weight pully $120
NEW Rear Leaf Spring Bushings $20
NEW Ignition/starter/accessory longacre switch board w fuses $60
Tilton Three Master Brake cylinders- Racing grade
NEW Front Brake Cylinders Not Installed $100
NEW Slotted Rotors, Not installed $200
NEW Front Pads, Not installed $100
NEW Rear Brake Shoes Not installed $100
NEW Fuel Pressure Regulator $40
Recent Rebuilt Engine
Quaife LSD
Pistons 12:1
Rocker Tilton roller rockers Performance grade
Carillo rods
Window Net $50
Fire Suppression System
Tilton brake and clutch system,
upgraded hydraulic clutch system,
Tilton aluminum flywheel,
llightened aluminum engine backplate,
custom built dog ring
gearbox,
Spax adjustable shocks,
Double bearing rear
hubs,
panhard bar
Rear Axles 2 spares
Straight Cut Dog gear transmission
Rear Axle Differential gear ratio 4.55 9x41
Near new Clutch plate and flywheel
NEW Harness installed expires 2025 $150
NEW 2nd Harness Not installed.
Radiator spare
10 Gallons of 110 Racing fuel $80 in containers, plus what is in fuel tank.
Weber tuning books $30
Repair Manuals $50
Anal Professional Mechanic Serviced and installed parts on this car
Boxes of used spare parts including MSD Ignition Controller, at least two distributors, body parts, intake and exhaust manifold, used Weber 45 DCOE carburetor, too much to remember.
Windshield
Reason I'm selling is that this 79 year old body isn't having fun doing the sport by itself.
A buyer's commitment to RMVR or other Vintage racing club will help with price negotiations.
Sale Price of $14,950 includes over $6,580 in NEW parts and lots of used spare parts. The price equates to less than $8,370 for this ready to race vintage car. (I did the math for you.)
This small bore production car is ready to enter the next vintage race event.
1200+ CC
NEW Fuel Cell $300
NEW Fuel Pump $100
NEW Starter $100
Quaife LSD
Pistons 12:1
Carillo rods
Window Net $50
gearbox,
Double bearing rear
hubs,
panhard bar
Rear Axles 2 spares
Radiator spare
Repair Manuals $50
Windshield
