1966 Sprite interior panels
Whitephrog
My recently acquired 1966 Spite project came with a set of interior panels without the vinyl covering. I'm not certain that the panels are original. They appear to a bit crudely cut, not very precise. There are holes around the edges as if there had been attached in the past. The rear panel that separates the boot area from the cockpit was made of plywood and wrapped with am ochre colored vinyl (autumn leaf) that looks to be original. Does any of this seem to be correct?
RickB
I'm kind of in the same boat with my 64 Sprite, lots of little panels covered with a hideous light brown color vinyl. I want to change it all to black, so what I want is a good source for black vinyl that will look "right" in the car.
I can recover the panels, I can cut new by using the old as a pattern.
Should I just ask my wife to take me to a fabric place?
Jim_Gruber
Rick,
You can find suitable stuff that looks good at any of the Chain Fabric Stores. And you can go there without your wife. Vinyl as well as thin foam backing sold by the yard. Those women in there love to help men who have no clue as to what they are looking for.
RickB
Ah - that's the plan then!
I'm good at looking clueless :wink:
68_sprite
Rick, Pacific Fabrics has a pretty good stock of different vinyls, but my favorite place for car fabric stuff is down at the old B & I in Tacoma. It is a kind of divey type area, but the woman who owns it does a ton of car interiors. She also has a good supply of vinyl in stock and books to order almost anything you need. When I recovered the panels the first time, that is where I went. She is very helpful.
RickB
Thank you, I don't get to Tacoma that often but this might be worth a special trip.
68_sprite
I havent' found anything close to the selection she stocks. Some of the auto interior shops carry and order vinyl, but they were about double the cost. Worth the cost of gas to get there.
Jim_Gruber
I also found that thin foam that you can buy works well under the panels. Gives them some dimension and if panels are sort of cruddy to begin with hides a lot of sins. Do not as I found out try to use thin fabic batting. It looks good until you try to drill the panels and the fabric wraps around the drill bit and tears up the vinyl. BTDT.
George Zeck
Raay -
When I bought my seats from the ebay guy - he had me buy from these guys. I think is was $10 / yard (could have been more) -- it was cheaper than a local fabric store. Bought 6 yards for the entire car and had some to mess up with.
https://www.silverstatefabrics.com/
Geo
HAN8L1965
As mentioned you can by vinyl with a foam backing. Check the fabric stores and marine vinyl sites on line. Large selection available at reasonable prices. I redid the interior of a boat with the padded back easy to use and strech when needed. Our panels will benefit from the foam backing as it gives a softer feel to the finished product.
Mark
W
Whitephrog
Back to the original question. What do the naked panels look like? Material? Preciseness of cut around the edges? Was the panel that separates the boot from the cockpit made from plywood?
theleisure
Bronze
All of the interior panels that I've ever seen have been made out of board that was similar to masonite. Who knows if that was original as they were on my father's cars.
I work in the sign industry and we substitute pvc board(Komacel) for wood all the time. That's what I'll be using if I ever have to redo the panels in my car. There's a product called star-board that is available at marine supply shops. I'd consider star-board before masonite but it's not as good as Komacel.
George Zeck
I agree with the above that star-board is better. I priced it and it came to $near $300 for the boards + foam + vinyl and $20 for masonite @ Home Depot.
I went the cheap route -- willing to redo one later for the cost diff and I bought pleanty of vinyl.
Geo
Jim_Gruber
Ray,
The original panel that separates cockpit from trunk was fiberboard / cardboard painted I believe not covered in vinyl. I went with plywood so it was sturdy and a nice platform to install a set of 6 x 9" speakers. Covered with carpet, it looks nice.
spritenut
The panels are made from 1/8" masonite AKA tempered hardboard and a few other names, about $8-$10 for a 4x8 sheet at most lumber or home stores.
It's dark brown and smooth on one or both sides.
Do NOT use 1/4" and do NOT use anything thicker than 1/8" foam backer.
The window cranks will rub and wear if you do. The inner door latch will be a bear to fit too.
The car/trunk panel was also 1/8" and can be made with the kink in it using a piece of duct tape along a cut where the bend is.
Do be careful with fabric store vinyl as it is not the same grade or as stretchable as auto/marine vinyl. It will dry out and crack in no time.
W
Whitephrog
Thanks all. From this thread it's obvious that my panels are an imperfect copy of a set of originals. I'm going to toss them today and start fresh. Already have some 1/8" masonite from Home Depot that I was going to use for Bugeye panels but ordered those from AH Spares a few days ago. "68 Sprite" has offered a set of paper patterns so I'm good to go.
W Sound 1966 Sprite rolling chassis Spridgets 0
PHerder ? about the rear section of the cockpit on a 1966 Sprite MkIII Spridgets 9
W 1966 Sprite seat belts Spridgets 7
W Bugeye and 1966 sprite Parts Spridgets 8
W Parting out a 1966 MKIII Sprite Spridgets 4
abarth69 Flasher 1966 Sprite Spridgets 4
Luke_Healey 1966 Sprite horn circuit workings? Spridgets 3
M 1966 Mk 3 Sprite Rims Spridgets 6
R 1966 MK III Sprite Austin Healey 9
M 1966 Sprite dashboard Austin Healey 4
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J MGB 1966 MGB won't start MG 1
J MGB Just bought a 1966 MGB MG 50
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
S 1966 Austin cab British Motor Corp 2
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
K 1966 Austin 1100 carbs? British Motor Corp 1
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
C MGB 1966 MGB windshield glass MG 4
Keoke 1966 AH BJ8 on eBay Austin Healey 18
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
M 1966 BJ8 Top Austin Healey 1
3798j General TR 1966 12 Hours of Sebring Triumph 0
1 MGB 1966 MGB hard shifting into 3rd MG 1
AHS Spitfire 1966 Spitfire with title for parts Lancaster PA NFI, $100 Triumph 3
Zimmycobra For Sale Misc. External Engine Parts - 1966 TR4A Triumph Classifieds 1
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
Zimmycobra For Sale Original 1966 TR4A Radiator Triumph Classifieds 0
Zimmycobra For Sale Original 1966 TR4A 60 Spoke painted wire wheels Triumph Classifieds 0
J For Sale For Sale-1966 MG Midget Disassembled Other British Classifieds 0
N TR4/4A 1966 Tr 4a, seats Triumph 7
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
AH67 1E120049 1966 Jaguar XKE Roadster Jaguar 1
L 1966 BJ8 frame rebuilding questions Austin Healey 1
tr6nitjulius What happened to Barn Find 1966 E-Type 4.2 Coupe? Jaguar 0
L 1966 BJ8 rear trim panels Austin Healey 8
D distrubutor wiring for 1966 BJ8 Cap to plugs Austin Healey 3
S Floor Mats for 1966 Series 1 Coupe Jaguar 2
ekamm 1966 race start Triumph 14
R 1966 MG Midget MK11 Dash Spridgets 4
K 1966 Austin healey 3000 Austin Healey 10
AngliaGT 1966 Studebaker...... Spotted 2
Pythias Wanted.. Obscure Part[s] for 1966. Spridgets 12
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
